Controlling RF Transmitter Power via Microcontroller and SPI for Battery Operation
285 7
  • #1 21662370
    Ibrahim Khaleel
  • #2 21662371
    Timothy Shuck
  • #3 21662372
    Pieter Kruger
  • Powering MCU only on capacitive touch event
    #4 21662373
    Ibrahim Khaleel
  • Power-gating the MCU and RF chip with touch switch
    #5 21662374
    Ibrahim Khaleel
  • Microcontroller output can power low-current transmitter directly
    #6 21662375
    Steve Lawson
  • #7 21662376
    Ibrahim Khaleel
  • Use low-power sleep mode with periodic wake polling
    #8 21662377
    Steve Lawson
The discussion addresses controlling power to an RF transmitter connected via SPI to a microcontroller in a battery-powered home automation system. The main challenge is to power the microcontroller and RF chip only when transmitting commands triggered by capacitive touch switches, to conserve battery life. Suggested solutions include using a MOSFET as a low-side or high-side switch controlled by a microcontroller I/O pin to power the RF transmitter on demand. Alternatively, if the RF chip supports an enable or power-down (PDN) pin, it can be toggled to reduce power consumption without fully cutting power. Another approach is leveraging the microcontroller’s low-power sleep modes to keep it mostly off, waking periodically to poll the capacitive touch switch, thus minimizing current draw. The specific components discussed are the Microchip MRF24J40MB RF transceiver and the Atmel ATmega16 microcontroller. Considerations include ensuring the MOSFET can handle the transmitter’s current and matching power requirements if powering the transmitter directly from a microcontroller pin. Battery selection and efficient power management are critical due to the limited battery life when continuously powered.
