How to Generate 10kHz–10MHz AC Signal at 0.6–2A: Signal Generator or DC-AC Conversion?
504 22
How can I generate a 10 kHz–10 MHz AC signal at 0.6–2 A, and can I boost a signal generator’s output safely or convert DC to AC instead?
Use a wideband linear power amplifier, typically a buffer stage followed by a power stage, after the signal generator; that is the normal way to raise current while keeping the sine shape [#21664209][#21664215] A signal generator does not supply the load current directly, so it should not be damaged by the amplifier if the amplifier is designed properly, because the amplifier uses its own power supply [#21664210] At 10 MHz, the key requirement is amplifier bandwidth and flat response over the whole range, and the needed output voltage matters just as much as current; one reply notes that an emitter follower only works in a limited voltage situation [#21664215][#21664216] If you test the generator into a very low resistance like 3 Ω, remember the generator is usually specified for a much higher load such as 50 Ω, so the displayed setting may not be the actual voltage across your load [#21664222][#21664223] The thread also notes that 10 MHz is not especially high, but getting a low-distortion, flat wideband amplifier that can really deliver 2 A is the hard part [#21664209][#21664215][#21664224]
  • Need a power amplifier for 10 kHz–10 MHz AC
    #1 21664207
    chunkit poon
  • #2 21664208
    Syed Shadab
  • #3 21664209
    Earl Albin
  • #4 21664210
    Steve Lawson
  • #5 21664211
    chunkit poon
  • #6 21664212
    chunkit poon
  • #7 21664213
    chunkit poon
  • #8 21664214
    Steve Lawson
  • Emitter follower buffer amplifier recommendation
    #9 21664215
    Earl Albin
  • #10 21664216
    Steve Lawson
  • #11 21664217
    chunkit poon
  • Signal generator output is low-current only
    #12 21664218
    chunkit poon
  • #14 21664220
    Steve Lawson
  • Direct coupling likely biases transistor off
    #15 21664221
    Steve Lawson
  • Measure actual voltage across the 3 ohm load
    #16 21664222
    Steve Lawson
  • Use a generator load within its rated output impedance
    #17 21664223
    Steve Lawson
  • 10 MHz is not microwave frequency
    #18 21664224
    Earl Albin
  • #19 21664225
    madhurika Shrivastava
  • #20 21664226
    chunkit poon
  • Correcting wavelength and unit mistakes
    #21 21664227
    Steve Lawson
  • #22 21664228
    Steve Lawson
  • #23 21664229
    Per Zackrisson
The discussion addresses generating an AC signal from 10 kHz to 10 MHz at currents between 0.6 A and 2 A. Standard signal generators can produce the required frequency range but typically output low current (~200 mA). To achieve higher current, the recommended approach is to use a wideband linear power amplifier or a buffer stage with power transistors (e.g., TIP32) to boost current without damaging the signal generator, as the amplifier supplies its own power. The term "wideband" refers to an amplifier with a flat frequency response over the desired range (e.g., 1 kHz to 10 MHz) and low distortion. Simple emitter follower transistor circuits can be used but require proper biasing and coupling (usually capacitor coupling) to maintain signal integrity and handle AC current flow. Directly loading a signal generator with low impedance (e.g., 3 Ω resistor) is not advisable as it may not deliver the expected voltage or current due to output impedance limitations (commonly 50 Ω). Measuring actual voltage across the load with an oscilloscope is necessary to verify performance. Achieving 2 A at 10 MHz is challenging and may require specialized RF power amplifiers or commercial kits, though such kits may not always meet the current requirements. Converting DC to high-frequency AC signals is possible but complex at these frequencies. The discussion also clarifies misconceptions about frequency ranges, emphasizing that 10 MHz is not microwave frequency and is relatively low in RF terms.
TL;DR: To get 0.6–2 A at 10 kHz–10 MHz, drive a wide‑band power amplifier from your signal generator; ≈4 W into 3 Ω at “5 Vpp,” and remember: “The signal IS the voltage.” [Elektroda, Steve Lawson, post #21664221]
Why it matters: This FAQ helps beginners turn low‑current generator outputs into amp‑level AC without frying gear, clarifying loads, biasing, and measurement.
What’s the simplest path to 0.6–2 A from 10 kHz–10 MHz?
Use your signal generator as the source, add a buffer, then a wide‑band power stage rated for your load current. Provide a suitable power supply. This chain preserves waveform while delivering current. Start by defining required peak voltage at the load, then size the amplifier’s current and thermal margins accordingly. Many inexpensive parts can reach 10 MHz if layout is careful. [Elektroda, Earl Albin, post #21664209]
Will an external amplifier damage my signal generator?
No. A proper amplifier uses its own supply to deliver power; it does not pull power from the generator. The generator supplies only the input signal. Ensure input levels match the amplifier’s specs to avoid clipping. Use AC coupling or attenuation if the amplifier needs it. [Elektroda, Steve Lawson, post #21664210]
What does “wide‑band amplifier” really mean here?
It means the amplifier maintains near‑constant gain and low distortion over the entire band. A practical shorthand is ±3 dB flatness between the lower and upper cutoff, such as 1 kHz to 10 MHz. Source impedance should stay low and distortion minimal across that span. Design biasing and layout for stability. [Elektroda, Earl Albin, post #21664215]
Is 10 MHz considered microwave or unrealistic for DIY?
It is not microwave. 10 MHz is a relatively low RF frequency and is very obtainable with common components and careful layout. Many bench projects operate comfortably at or beyond this region. Focus on bandwidth flatness and load driving, not on reaching 10 MHz itself. [Elektroda, Steve Lawson, post #21664220]
Can a single transistor work, and what about AC or reverse current?
A single‑transistor emitter follower can provide current gain with near‑unity voltage gain. It works if the required output voltage is lower than the generator’s maximum minus about 0.7 V. Use coupling capacitors to pass AC and set the DC bias. For higher voltages or symmetric swing, use push‑pull stages. [Elektroda, Steve Lawson, post #21664216]
Why didn’t my 3 Ω resistor heat up at 5 Vpp?
Panel Vpp assumes a matched load. With a heavy 3 Ω load, actual voltage can be far lower than indicated. Measure the true voltage across the resistor with a scope at the test frequency. The generator’s 50 Ω source and current limits reduce delivered power if the load isn’t matched. [Elektroda, Steve Lawson, post #21664222]
What does a “50 Ω output” on a signal generator imply?
It means the generator behaves like a 50 Ω source and its amplitude settings target a 50 Ω termination. If you connect a different load, the delivered voltage changes. Always verify voltage across the actual load rather than trusting the front‑panel setting. “Never trust what is written on a device.” [Elektroda, Steve Lawson, post #21664222]
How should I bias a simple transistor stage for this job?
Don’t leave the device near cutoff. Class‑A or a properly biased emitter follower avoids distortion. One reply flagged an example as mis‑biased (closer to class‑C). Add input AC coupling, set a midpoint bias, and ensure the load sees the intended swing. [Elektroda, Steve Lawson, post #21664221]
How do I verify real output voltage and power (quick 3‑step)?
  1. Terminate the generator with its intended load (e.g., 50 Ω) or through your amplifier into the actual load.
  2. Measure voltage across the load with a scope at the operating frequency.
  3. Compute power from measured RMS (P = V²/R) to judge heating and current. [Elektroda, Steve Lawson, post #21664222]
What is a CRO?
CRO stands for cathode ray oscilloscope. It displays voltage versus time and lets you read amplitude and frequency. Use proper probes and bandwidth to ensure accurate AC measurements at 10 kHz–10 MHz. [Elektroda, chunkit poon, post #21664226]
What is an emitter follower in plain terms?
It is a transistor stage with voltage gain near 1 but significant current gain. You drive it from a buffer, then AC‑couple to the load. It presents low output impedance, useful for current boosting without large voltage amplification. Layout and bias still matter at 10 MHz. [Elektroda, Earl Albin, post #21664215]
What happens if I load a signal generator with 3 Ω directly?
You can overstress the generator. Its 50 Ω output is not designed for such a heavy load. The generator may sag, distort, or enter protection. Use the correct termination or add a power amplifier designed to drive low impedances safely. [Elektroda, Steve Lawson, post #21664223]
