Behavior of a Resistor and Diode Connected in Parallel in a Circuit
354 14
What happens when a resistor and a diode are connected in parallel?
A resistor and a diode in parallel do not become "just a diode"; the current splits between the two branches, and the exact division depends on the diode bias and the resistor value [#21664404][#21664402] If the diode is reverse-biased and not in avalanche or breakdown, only reverse leakage current flows through the diode, while most current goes through the resistor [#21664404] If the diode is forward-biased, it has a roughly constant forward voltage, the resistor has the same voltage across it, and its current is found by Ohm’s law, I = V/R [#21664404] If the diode is in avalanche or breakdown, it again holds a fairly constant voltage and the current is limited by the source/internal resistance [#21664404] In the special case of a zero-ohm branch, essentially all current takes that path; otherwise, the current divides between the branches [#21664404]
  • #1 21664392
    sajjad Asefi
  • #2 21664393
    Frank Bushnell
  • #3 21664394
    sajjad Asefi
  • #4 21664395
    Steve Lawson
  • Plotting LED I-V curve against resistor load line
    #5 21664396
    David Adams
  • #6 21664397
    Steve Lawson
  • #7 21664398
    David Adams
  • #8 21664399
    Steve Lawson
  • #9 21664400
    Muazu Musa
  • #10 21664401
    sajjad Asefi
  • Parallel resistor skews the diode characteristic
    #11 21664402
    Steve Lawson
  • #12 21664403
    sajjad Asefi
  • Current division depends on diode bias state
    #13 21664404
    Steve Lawson
  • #14 21664405
    David Adams
  • #15 21664406
    Steve Lawson
The discussion addresses the electrical behavior of a resistor and diode connected in parallel. The outcome depends on several factors including the type of input voltage (AC or DC), polarity, resistor value, diode type, and diode peak inverse voltage (PIV). Generally, current favors the path of least resistance, so if the resistor has very low resistance, most current will bypass the diode, potentially preventing it from conducting or lighting up if it is an LED. The diode's I-V characteristic curve compared to the resistor's linear characteristic determines current distribution; when the diode's curve surpasses the resistor's, diode current increases significantly. In practical terms, the resistor's effect can often be neglected if its resistance is high relative to the diode's conduction path, but it never truly "disappears." Different diode biasing conditions (forward, reverse, avalanche) affect current flow, with reverse leakage current being minimal unless breakdown occurs. The discussion also clarifies that zero resistance in parallel means all current flows through the resistor path, effectively bypassing the diode. The question of series connection of resistor and diode was briefly raised but not deeply explored.
TL;DR: A silicon diode in parallel with a resistor sets about 0.6–0.7 V across both; “current will divide between the two.” Source resistance ultimately limits current in forward or breakdown modes. [Elektroda, Steve Lawson, post #21664404]
Why it matters: This helps you predict current sharing, avoid diode damage, and design safe clamps or shunts in real circuits.
What happens when a resistor and diode are connected in parallel on a DC source?
Both parts share the same voltage. In forward bias, the diode fixes about 0.6–0.7 V, so the resistor current is Ir ≈ Vd/R. Total current is set by source resistance; the diode takes the balance. [Elektroda, Steve Lawson, post #21664404]
Does all current go through the diode if it’s forward biased?
No. Current splits between the diode and the resistor based on their I–V curves and the source’s internal resistance. “Otherwise, the current will divide between the two.” [Elektroda, Steve Lawson, post #21664404]
What if I short the diode with a 0 Ω resistor in parallel?
A true 0 Ω shunt takes 100% of the current, and the diode current is 0 A. Any nonzero shunt will split current with the diode. [Elektroda, Steve Lawson, post #21664404]
How does the circuit behave in reverse bias?
Below breakdown, only tiny reverse leakage flows through the diode; the resistor carries almost everything. In breakdown, diode voltage is roughly constant while source resistance limits current. [Elektroda, Steve Lawson, post #21664404]
Will the resistor ever ‘not exist’ when paralleled with a diode?
It asymptotically looks negligible as the diode clamps voltage, but the resistor still draws Vd/R current. It never truly disappears. [Elektroda, Steve Lawson, post #21664402]
Is this the same as having just a diode in parallel?
Not exactly. The resistor skews the composite I–V curve and increases total current at the diode’s clamped voltage. Behavior depends on R and source resistance. [Elektroda, Steve Lawson, post #21664402]
How do I estimate currents quickly without solving exponentials?
Use a diode drop approximation. Assume Vd ≈ 0.6–0.7 V (small I) or ≈1–1.5 V (large I), then compute Ir = Vd/R and It = (Vs − Vd)/Rs. [Elektroda, Steve Lawson, post #21664404]
What’s the failure or edge case I should watch for?
With a low-R source, diode current can skyrocket in forward or breakdown mode and overheat the junction—visible smoke is possible. Add series resistance. [Elektroda, Steve Lawson, post #21664404]
How does AC input change the behavior?
During positive half cycles (forward bias), the diode clamps near its forward drop and shares current with the resistor. During negative cycles, leakage flows unless breakdown is reached. [Elektroda, Steve Lawson, post #21664404]
What did the original thread mean by ‘no resistance’?
One post clarifies that “no resistance” means infinite resistance (open circuit), not zero. Precision avoids confusion in analysis. [Elektroda, David Adams, post #21664405]
What if the resistor and diode are in series instead of parallel?
Series connection limits diode current. You pick R so Vd is reached without exceeding current limits; it’s a safer, predictable configuration. [Elektroda, Steve Lawson, post #21664402]
How can I visualize current sharing between a resistor and a diode?
Plot the diode’s I–V curve and overlay the resistor’s load line at the applied voltage. Their intersection gives operating current and voltage. [Elektroda, David Adams, post #21664396]
Can a reverse-biased diode with a parallel resistor be used as a clamp?
Yes. In breakdown, the diode holds near its breakdown voltage while the resistor and source resistance set current. Ensure current stays within limits. [Elektroda, Steve Lawson, post #21664404]
Do LEDs behave differently in this parallel setup?
Principles match, but LED forward voltage varies with color and current. The resistor will still take Vd/R at the LED’s drop. [Elektroda, Steve Lawson, post #21664402]
Quick how-to: analyze a diode‖resistor at a given supply voltage.
  1. Approximate the diode drop (e.g., 0.7 V) or its breakdown value.
  2. Compute resistor current Ir = Vd/R and total It = (Vs − Vd)/Rs.
  3. Verify diode current Id = It − Ir is within safe limits. [Elektroda, Steve Lawson, post #21664404]
What does “PIV” or reverse voltage rating mean here?
It’s the maximum reverse voltage before breakdown risk. In this parallel circuit, ensure supply never exceeds the diode’s reverse rating. [Elektroda, Steve Lawson, post #21664404]
