Current Sensing Resistors Applications: What Circuits or Projects Are You Using Them In?
267 9
What circuits or projects are current sensing resistors commonly used in?
They are commonly used in linear and switching power supplies to measure and regulate current, including battery chargers and current-mode supplies. [#21664408] [#21664412] They are also used in LED driver circuits, especially switch-mode boosters for series LED strings and high-power LEDs, and for maximum-current rollback in power supplies. [#21664409] [#21664413] Other applications mentioned include protection circuits that limit transistor current, amplifier protection, PWM supplies with op-amp comparator circuits, and ADC/current-sense inputs for microcontrollers such as PICs. [#21664412] [#21664413] Motor-drive and robotics projects use them for torque sensing and to detect wheel slippage, including H-bridge drivers and vehicle window modules. [#21664413] [#21664414] They also appear in test equipment. [#21664413]
  • #1 21664407
    Roy Furtado
  • #2 21664408
    Boi Okken
  • #3 21664409
    Steve Lawson
  • #4 21664410
    alina Mack
  • Distinguishing shunt and sense resistor roles
    #5 21664411
    Steve Lawson
  • #6 21664412
    Todd Hayden
  • #7 21664413
    Mark Harrington
  • #8 21664414
    Timothy Shuck
  • #9 21664415
    NIKILA
  • #10 21664416
    NIKILA
Current sensing resistors are widely used in various electronic circuits and projects primarily for measuring and regulating current. Common applications include linear and switching power supplies, battery chargers with regulated current, and LED drivers using switch-mode boosters for series or high-wattage LEDs. They are also employed in protection circuits to limit maximum current through transistors, motor drive circuits for torque sensing, and robotics for motor current sensing to detect conditions like wheel slippage. Current sensing resistors often work in conjunction with microcontrollers, ADCs, op-amp comparator circuits, and H-bridge drivers. A distinction is made between current sense resistors and shunt resistors: shunt resistors are placed across a meter to extend its range by shunting current, whereas sense resistors are placed in series to measure current for feedback or control purposes.
