Low Voltage Differential Signaling (LVDS) Receiver Design References and Key Info
387 6
  • #1 21664683
    Ashish Kumar Maddheshiya
  • Op amp differential receiver with input buffers
    #2 21664684
    Cody Tappan
  • #3 21664685
  • #4 21664686
    Mark Harrington
  • #6 21664688
  • #7 21664689
    Floy Viola
The discussion focuses on designing a Low Voltage Differential Signaling (LVDS) receiver, emphasizing the need for detailed information and references. For a basic class project without strict input impedance requirements, a simple differential amplifier using an operational amplifier (op amp) with unity gain is suggested. If input impedance is a concern, adding voltage follower buffers with additional op amps at the inputs is recommended. For comprehensive technical details and design guidelines, a Texas Instruments application note (sllu016c.pdf) is provided as a valuable resource. General advice includes researching LVDS receiver schematics and circuits through search engines to find practical examples and design references.
