Calculating Inductance for Laminated Iron Core Coils—Formulas and Parameters
660 9
How do I calculate the inductance of a laminated iron-core inductor and choose the core, turns, wire size, and air gap for a low-frequency design?
Use the core’s Al value for the chosen EI lamination set and compute turns from the inductance target with N = √(L/Al); the thread gives an example of 5 mH with Al = 1 mH/1000 turns² requiring 2236 turns [#21665131] The core charts already relate a specific core size and winding form (bobbin) to nominal inductance, so the design starts by selecting the EI core and reading its inductance-vs-turns data [#21665131] Laminated steel cores are mainly for low-frequency use such as 50/60/1000 Hz, and changing the geometry changes the inductance because magnetic path length and proximity matter [#21665125][#21665129] The replies also note that laminated inductors usually do not have an air gap, though one can exist, and that eddy-current losses are the reason for the laminations [#21665125][#21665129]
  • #1 21665122
    Bernat Feixas
  • #2 21665123
    Earl Albin
  • #3 21665124
    Bernat Feixas
  • Laminated inductors usually have no air gap
    #4 21665125
    Earl Albin
  • Toroidal cores are more flux-friendly than laminated plates
    #5 21665126
    Yoram Stein
  • Google is not a reliable source for inductor design
    #6 21665127
    Earl Albin
  • Lamination does not significantly change coil permeability
    #7 21665128
    Yoram Stein
  • Laminations reduce eddy currents, but geometry sets inductance
    #8 21665129
    Earl Albin
  • #9 21665130
    Bernat Feixas
  • Using Al value to calculate turns for target inductance
    #10 21665131
    Earl Albin
The discussion addresses the challenge of calculating inductance for laminated iron core coils, specifically for low-frequency applications such as 10H inductors at 400mA. Key design steps include selecting the appropriate EI laminated core, determining the thickness of the lamination stack (bobbin size), calculating the number of turns and wire diameter, and considering the presence or absence of an air gap. Laminated cores are used primarily to reduce eddy current losses at 50/60 Hz, and their geometry significantly affects inductance and efficiency. The concept of the Al value (inductance per turns squared) is crucial for calculations, allowing determination of required turns for a desired inductance using the formula N = sqrt(L_desired / Al). Various online coil calculators and references were suggested, but it was emphasized that accurate magnetic design requires understanding of magnetic properties and geometry rather than relying solely on generic tools. Laminations refer to the steel plates in the core separated by insulation to minimize eddy currents, not to insulation between coil turns. The discussion also notes that laminated cores typically do not have air gaps, though gaps can be introduced if needed. For precise design, consulting specialized magnetics manufacturers or detailed magnetic design resources is recommended over general internet searches.
