Suggestions for Final Year UPS Project with Microcontroller Integration for Industrial Electronics
330 8
  • Requesting microcontroller-based UPS project suggestions
    #1 21667585
    m Sam
  • Basic UPS blocks: charger, inverter, changeover switch
    #2 21667586
    Rohit Dubla
  • #3 21667587
    kassim Abba
  • #4 21667588
    kassim Abba
  • #5 21667589
    Mark Harrington
  • Recommended background for UPS inverter projects
    #7 21667591
    Mark Harrington
  • #8 21667592
    Avril Cory
  • Add battery monitoring and Modbus RS-485 diagnostics
    #9 21917573
    neilcole638
    If the goal is to make the project closer to real industrial applications, consider adding features beyond basic UPS functionality. For example, battery health monitoring, load management, fault logging, temperature monitoring, and communication over Modbus RS-485. A microcontroller can be used not only for charging and inverter control but also for diagnostics and predictive maintenance. Projects that combine power electronics with monitoring and industrial communication usually stand out more during final-year evaluations.
The discussion focuses on selecting a final-year industrial electronics project based on a UPS with microcontroller integration. Suggested project blocks include a battery charger, DC-to-AC inverter, and an automatic changeover circuit that detects mains failure and switches the load to battery/inverter operation. Additional advice recommends making the project more industrially relevant by adding microcontroller-based control, PWM, ADC, battery health monitoring, temperature sensing, fault logging, load management, and communication such as Modbus RS-485. Several schematic references and inverter circuit examples are mentioned as starting points for design.
