Best OP amp upgrades for vintage audio gear—where to start and recommended models?
339 6
  • #1 21667996
    Jeremy Brannon
  • Capacitor replacement before op-amp upgrades recommended
    #3 21667998
    Rohit Dubla
  • Recommend unity-gain-stable audio op amps and sockets
    #4 21667999
    Kevin Parmenter
  • Recommend Walter Jung’s op-amp design book
    #5 21668000
    Mark Harrington
  • Recommend rugged Fostex or Mackie pro gear
    #6 21668001
    Mark Harrington
  • Recommend Fostex or Mackie pro gear instead
    #7 21668002
    Mark Harrington
Upgrading operational amplifiers (op-amps) in vintage audio equipment requires careful consideration of the original circuit design and component condition. Before op-amp replacement, it is advisable to check and possibly replace aging electrolytic capacitors, especially in frequency-shaping circuits, with equivalent or higher voltage-rated components to maintain intended performance. Op-amp upgrades should favor unity gain stable devices to avoid oscillations, as older circuits may lack proper compensation for modern high-speed or exotic op-amps. Commonly recommended audio-grade op-amps include the NE5532, with Analog Devices and Texas Instruments offering suitable models. Using DIP packages with sockets facilitates easy swapping and comparison. Additionally, upgrading audio path capacitors to film types can improve sound quality. Resources such as diyaudio forums and technical articles provide valuable guidance. For deeper understanding, the book "Audio IC Op Amp Applications" by Walter G. Jung is recommended. Some responses suggest considering modern amplifier technologies (Class D, Class GH) or investing in robust, well-built gear from brands like Fostex and Mackie for better reliability and performance.
