How to Convert Car Speed Pulse Signal to Digital Display for DIY Heads Up Display?
318 12
How can I convert a car speed pulse signal into a digital speed display for a DIY heads-up display?
You don’t need a D/A converter; count the pulses with a frequency counter or a small microcontroller, and if the signal is two pulses per mph you can divide it by 2 for a direct speed reading [#21668888][#21668890] A microcontroller is often the easiest approach because it can read a spare input, use its built-in counters, and drive the display, with a ceramic resonator as the clock source [#21668890][#21668892] Because automotive signals are noisy, put an optoisolator on the input, preferably an AC-input type, to protect against negative transients [#21668890] For the HUD optics, use very bright LEDs and a half-silvered mirror or similar coating so the image reflects to your eyes while still letting you see the road, and dim the LEDs at night [#21668888] For a simple first version, you can also feed the divided pulse output into a digital LED readout and reflect it with a small mirror [#21668897]
  • Need pulse-to-speed conversion for HUD display
    #1 21668887
    Tim Gurske
  • Use a frequency counter and half-silvered mirror
    #2 21668888
    Mark Nelson
  • #3 21668889
    Tim Gurske
  • Use a microcontroller with optoisolated pulse input
    #4 21668890
    Stephen Van Buskirk
  • Discrete 7-segment driver avoids microcontroller
    #5 21668891
    Mark Nelson
  • Microcontroller simplifies pulse counting and display smoothing
    #6 21668892
    Stephen Van Buskirk
  • #7 21668893
    Tim Gurske
  • Persistence-of-vision display and scanning ideas
    #8 21668894
    Mark Harrington
  • OLED-on-glass display ideas for shop windows
    #10 21668896
    Mark Harrington
  • Use a digital tachometer and mirror for HUD display
    #11 21668897
    Frank Bushnell
  • #13 21668899
    Ijaeee Journal
The discussion focuses on converting a car's speed pulse signal, which pulses twice per MPH, into a digital display suitable for a DIY heads-up display (HUD). The primary method involves counting pulse frequency using a frequency counter or a microcontroller with built-in counters to measure pulses per second, thereby deriving speed without analog-to-digital conversion. A divide-by-two flip-flop can simplify the pulse frequency to match MPH directly. Using a small microcontroller is recommended for flexibility, ease of configuration, and integration of smoothing algorithms to prevent display flicker, although simpler hardware-only solutions with discrete counters and 7-segment LED drivers are possible. An optoisolator is suggested for input protection against automotive electrical noise. For the HUD projection, high-intensity LEDs or digital tachometers with LED readouts can be used, reflected onto the windshield via a half-silvered mirror or coated plastic to maintain road visibility. The display brightness can be adjusted for day and night conditions. Advanced projection methods such as laser scanning or OLED integration into glass panels are mentioned as more complex alternatives. Several online resources and example circuits are referenced for further exploration.
TL;DR: Your car’s speed wire outputs 2 pulses per MPH (120 Hz = 60 MPH). “No analog conversions required”—count pulses or divide by two, then drive a display. [Elektroda, Mark Nelson, post #21668888]
Why it matters: This FAQ shows DIYers how to turn a noisy automotive pulse signal into a readable HUD speed display, safely and simply.
How do I convert a speed pulse wire into a digital speed readout?
Count pulses per second, then scale to MPH. With 2 pulses per MPH, divide the input by two with a flip‑flop and read the resulting Hz as MPH. No DAC is needed because you’re measuring frequency, not voltage. “No analog conversions required.” [Elektroda, Mark Nelson, post #21668888]
Can I do this without programming a microcontroller?
Yes. Build a discrete frequency counter and a divide‑by‑2 stage to feed a 7‑segment LED display. It uses more parts than a micro, but it avoids firmware, debuggers, and toolchains. This approach suits beginners who prefer wiring over coding. [Elektroda, Mark Nelson, post #21668891]
Why would I choose a microcontroller for a DIY HUD?
A small micro has built‑in counters, drives the display directly, and is easy to reconfigure. It reduces parts and simplifies adding smoothing so the number doesn’t flicker near thresholds. You can in‑circuit program and tweak scaling quickly. [Elektroda, Stephen Van Buskirk, post #21668892]
How do I protect the input from automotive electrical noise?
Use an AC‑input optoisolator between the vehicle speed wire and your counter or micro. It rejects negative transients and isolates the logic side. As the expert notes, “An AC input optoisolator would be proof against negative transients on the input.” [Elektroda, Stephen Van Buskirk, post #21668890]
What display and optics work for a windshield HUD?
Choose a high‑intensity LED display so digits remain visible in sun. Add dimming for night driving by reducing current. Reflect the display using a half‑silvered mirror so the road remains visible through it. Expect some trial to set the angle. [Elektroda, Mark Nelson, post #21668888]
Is there a quick, low-code way to prototype this?
Yes. After dividing by two, feed the signal to a panel digital tachometer module and use a small mirror to re‑invert and reflect onto the windshield. Many modules read up to 9,999, which is ample for speed. [Elektroda, Frank Bushnell, post #21668897]
What is a frequency counter in this context?
It’s a circuit or micro feature that counts input pulses over a fixed time to compute frequency. Here, frequency maps directly to MPH after the divide‑by‑2 stage, so 60 Hz indicates 60 MPH. You then display that value. [Elektroda, Mark Nelson, post #21668888]
What is a flip‑flop divider and why use divide‑by‑2?
A flip‑flop toggles state on each pulse. Feed it your speed pulses and the output frequency halves. Because your wire outputs 2 pulses per MPH, halving the frequency creates a direct MPH‑to‑Hz relationship for simple displays. [Elektroda, Mark Nelson, post #21668888]
How do I keep the speed digits from flickering between numbers?
If you use a micro, average several consecutive frequency measurements or apply hysteresis. That smooths readings near boundaries, like 59.9–60.1 MPH. It’s far easier to adjust smoothing in code than with extra hardware. [Elektroda, Stephen Van Buskirk, post #21668892]
Can I power the HUD from the car ignition line?
Yes, many DIY builds take 12 V from ignition and chassis ground. Still, isolate the signal path and condition the supply for noise. Use proper fusing and an optoisolator on the pulse input to safeguard electronics. [Elektroda, Tim Gurske, post #21668887]
What’s a simple 3‑step build plan to test the concept?
  1. Tap the speed wire and route it through an AC‑input optoisolator.
  2. Divide the signal by two using a flip‑flop.
  3. Count frequency and drive a bright LED display or tachometer, then reflect with a mirror. [Elektroda, Mark Nelson, post #21668888]
Will a basic LED panel be visible in daylight?
It can be, if it’s high‑intensity and properly angled toward a reflective combiner. Add current‑based dimming for night comfort. Expect some experimentation with mirror placement to optimize clarity and reflection. [Elektroda, Mark Nelson, post #21668888]
What is an Arduino Nano, and could it work here?
Arduino Nano is a small 5 V microcontroller board with timers that can count pulses and drive displays. It fits the suggested micro‑based approach and allows in‑circuit reprogramming to adjust scaling and smoothing. [Elektroda, Stephen Van Buskirk, post #21668890]
What is CAN bus, and do I need it for this HUD?
CAN bus is a vehicle network for modules to share data. This thread’s method reads the raw speed pulse, so you don’t need CAN decoding. Counting pulses remains simpler for beginners building a basic HUD. [Elektroda, Mark Nelson, post #21668888]
Any edge cases or failure modes I should plan for?
Automotive lines can carry voltage spikes and reverse‑polarity transients. Without isolation, these can latch or damage counters and micros. An AC‑input optoisolator on the signal greatly improves resilience and safety. [Elektroda, Stephen Van Buskirk, post #21668890]
Could I use a laser/scan projection instead of a simple display?
Advanced laser scanning HUDs are possible but significantly more complex to build and align. For a first project, stick to an LED display plus combiner. You can explore scanning concepts later for larger visuals. [Elektroda, Mark Harrington, post #21668898]
