Nidec TA350DC 4-Wire Fan Parallel Wiring: Why Do Fans Pulse and Not Run Together?
579 22
Why do these 4-wire Nidec DC fans pulse and fail to run properly when connected in parallel, and how can they be made to run together?
The fans likely need individual control or buffering rather than being tied straight in parallel, because their brushless electronics can draw fast current spikes and upset the supply, which makes them pulse instead of start cleanly [#21669197][#21669200] A suggested fix was to decouple the fans from the PSU with a battery or a low-ESR capacitor, with one reply recommending about 4700 uF to handle the spikes [#21669197] Another suggestion was to control each fan separately with its own FET path so each motor has its own loop [#21669200] In the end, the problem was solved by driving each fan through a simple LM317 voltage regulator [#21669201] That was used with a transformer, bridge rectifier, and capacitor supply, and then the fans worked properly together [#21669201][#21669202]
  • Shared tach signal likely causing fan pulsing
    #1 21669180
    Sarah Harris
  • Measure 12 V rail under increasing fan load
    #2 21669181
    Kevin Parmenter
  • #3 21669182
    Sarah Harris
  • Use FET switching for parallel fan control
    #4 21669183
    Mark Harrington
  • Parallel fan wiring with individual PWM control
    #5 21669184
    Mark Harrington
  • #6 21669185
    Sarah Harris
  • #7 21669186
    Mark Harrington
  • Shared PCB, Gerber, and Proteus design files
    #8 21669187
    Mark Harrington
  • Questioning parallel wiring of 4-wire fans
    #9 21669188
    Rodney Green
  • #10 21669189
    Mark Harrington
  • Sequential current testing to isolate fan fault
    #11 21669190
    Mark Harrington
  • Back-emf from parallel fans disrupts supply readings
    #12 21669191
    Sarah Harris
  • Clarifying fan alarm signal and test setup
    #13 21669192
    Mark Harrington
  • #14 21669193
    Mark Harrington
  • Clarify fan pinout and model numbers
    #15 21669194
    Nick Brackenbury
  • Suggesting EMI test and LC decoupling filter
    #16 21669195
    Kevin Parmenter
  • #17 21669196
    Kevin Parmenter
  • 4700 µF low-ESR capacitor to handle fan current spikes
    #18 21669197
    DAVID CUTHBERT
  • High inrush current from dc-dc converters trips supply
    #19 21669198
    Mark Harrington
  • Advice to document everything and demand written agreements
    #20 21669199
    Mark Harrington
  • Use an accumulator and separate fan control loops
    #21 21669200
    Rodney Green
  • LM317 regulators used to drive each fan
    #22 21669201
    Sarah Harris
  • Advice to verify datasheets and test samples before bulk buying
    #23 21669202
    Mark Harrington
A user experienced issues when wiring multiple Nidec TA350DC 4-wire fans in parallel to a 12V supply: the fans pulsed slowly and failed to run simultaneously. Individually, each fan operated correctly. The problem persisted despite attempts to isolate fans with diodes and add capacitors. The discussion explored potential causes including insufficient power supply response to current spikes, interference from fan feedback signals, and the lack of proper PWM control for each fan. The datasheet confusion arose as the official TA350DC datasheet showed only two wires, while the user’s fans had four wires, likely including power, ground, tachometer, and control signals. Suggestions included using individual PWM control via MOSFETs, adding large low-ESR capacitors (e.g., 4700 µF) to stabilize supply voltage, and testing with alternative power sources like batteries to reduce EMI effects. The user ultimately resolved the issue by driving each fan through an individual LM317 voltage regulator combined with a transformer, bridge rectifier, and capacitor, ensuring stable and isolated power delivery to each fan. The discussion emphasized the importance of complete datasheet information and proper current distribution when paralleling electronically commutated DC fans.
TL;DR: Parallel-wired TA350DC 4‑wire fans can draw ~0.9 A each and “what ever these things give back to the power line is really quite disruptive,” causing pulsing. Isolate/decouple and test each fan individually before paralleling. [Elektroda, Sarah Harris, post #21669191]
Why it matters: This FAQ helps makers and repair techs fix pulsing Nidec 4‑wire fans wired in parallel without frying supplies or fans.
Why do my Nidec TA350DC 4‑wire fans pulse when wired in parallel?
Each fan’s internal driver injects noise and current spikes into the shared 12 V rail. In parallel, those spikes cross‑couple and upset the PSU, so the fans start/stop or “pulse.” The poster saw PSU readings go haywire whenever two fans were paralleled, confirming rail disturbance. Decoupling each fan and avoiding direct parallel drive eliminates the interaction. [Elektroda, Sarah Harris, post #21669191]
How can I fix pulsing fans without changing the model?
Give each fan its own driver path. One simple field‑proven approach is an LM317 per fan fed from a rectified, filtered supply. This isolates load dynamics so multiple fans start and run together. The thread author reported stable operation after switching to one LM317 per fan. [Elektroda, Sarah Harris, post #21669201]
Is my big bench supply still a suspect even at 40 A rating?
Yes. Large SMPS units can have control loops sensitive to fast load steps. With two fans, the rail showed erratic voltage/current despite ample nameplate current. That points to dynamic interaction, not average capacity. Battery testing and per‑fan isolation can confirm. [Elektroda, Sarah Harris, post #21669191]
What quick tests should I run to separate PSU issues from fan cross‑talk?
Power the fans from a 12 V battery. If pulsing stops, the original PSU loop is being disturbed. Add an inductor and capacitor between PSU and fans to decouple EMI. This helps verify whether EMI on the rail is the root cause. [Elektroda, Kevin Parmenter, post #21669195]
How do I wire PWM on these 4‑wire fans for basic speed control?
Use Red to +12 V, Black to GND. Drive the Blue wire with a PWM signal; an NE555 generator worked for speed control in the thread. Keep PWM ground common with the fan ground. This gives crude but functional speed control. [Elektroda, Sarah Harris, post #21669191]
What startup behavior should I expect from brushless DC fans?
Expect short, high inrush bursts before steady current. One case cited 30–40 A for a few microseconds on other switching loads, which can trip sensitive supplies. This underscores the need for decoupling and per‑fan drive when paralleling. [Elektroda, Mark Harrington, post #21669198]
Which capacitor should I try across the supply to tame spikes?
Start with ~4700 µF low‑ESR (≤0.1 Ω) across the output. This supports ~10 A transients with about a 3 V droop over ~1 ms, giving the PSU time to respond and smoothing spikes from multiple fans. [Elektroda, DAVID CUTHBERT, post #21669197]
Could current limit settings be causing the pulsing?
Yes. Set the PSU current limit high enough (e.g., >10 A) to avoid premature foldback during start or step changes. If the limit is too low, the supply may cycle and the fans will pulse instead of spinning up. [Elektroda, DAVID CUTHBERT, post #21669197]
How do I implement the per‑fan LM317 fix?
  1. Feed a transformer → bridge → bulk capacitor to create a stable DC rail.
  2. Use one LM317 per fan, wiring it as a regulator; set each output as needed.
  3. Connect each LM317 output to one fan’s 12 V input; keep grounds common. “Drive each fan through a simple LM317” solved the pulsing. [Elektroda, Sarah Harris, post #21669201]
Do I need one control loop per fan for PWM/tach setups?
Yes. Treat each fan as its own actuator. Provide individual switching/control so one failing or lagging fan does not drag others down. “Individual control of each fan” avoids cross‑coupling and maintains airflow if one unit stops. [Elektroda, Mark Harrington, post #21669202]
Why do my PSU meters go crazy when I parallel fans?
The fans’ drivers inject fast transients and noise back onto the rail. The thread showed PSU voltage and current readings becoming erratic as soon as two fans were paralleled, a hallmark of control‑loop disturbance. Decouple or isolate loads. [Elektroda, Sarah Harris, post #21669191]
What if my datasheet shows only 2 wires but my fan has 4?
Some TA350DC variants are 2‑wire; others have options like tach/PWM. A forum member flagged that the linked PDF showed only 2 wires, prompting the clarification that the hardware in hand was 4‑wire. Verify the exact model/options. [Elektroda, Nick Brackenbury, post #21669194]
Should I contact Nidec for the exact 4‑wire pinout and control spec?
Yes. Ask Nidec for the model‑specific 4‑wire application note or speak with an applications engineer. Vendor guidance can save time and confirm allowed PWM ranges and alarm wiring. [Elektroda, Kevin Parmenter, post #21669196]
What is an LM317, and why use it here?
LM317 is an adjustable linear regulator. Using one per fan creates separate supply paths, reducing interaction between fans and stabilizing startup. The thread author confirmed that this approach stopped pulsing with multiple fans. [Elektroda, Sarah Harris, post #21669201]
Edge case: both fans only start once their speeds match—what’s happening?
That indicates rail coupling: once both drivers reach similar loading, the interference cancels enough to allow spin‑up. The author saw hesitant starts that stabilized only when speeds synced, pointing to cross‑talk. Isolate to fix. [Elektroda, Sarah Harris, post #21669191]
