How to Add LFO Modulation to VCA Circuit Without Clipping at Low Control Voltages?
219 6
  • Need a level-dependent LFO attenuator for VCA modulation
    #1 21669871
    Patrick Edwards
  • #2 21669872
    DAVID CUTHBERT
  • Scaling LFO modulation with control voltage input
    #3 21669873
    Patrick Edwards
  • #4 21669874
    DAVID CUTHBERT
  • #5 21669875
    DAVID CUTHBERT
  • #6 21669876
    Patrick Edwards
  • Using op-amp or P-channel MOSFET current source
    #7 21669877
    DAVID CUTHBERT
The discussion addresses adding LFO modulation to an existing VCA circuit without causing clipping at low control voltages. The original VCA circuit uses a 4.5V key down and 0V key up control voltage feeding a 15k resistor into a 3906 PNP transistor with its base grounded, and the collector connected through a 10k resistor to the input bias of an LM3080 transconductance operational amplifier. The collector voltage swings from -15V (key up) to -12V (key down). The goal is to modulate this collector voltage with an LFO triangle wave swinging ±1.6V, such that the modulation depth scales with the control voltage: full swing (-15V to -12V) at 4.5V input, reduced swing at lower voltages, and zero output at 0V input. The LFO frequency range spans from 0.2 Hz to audio frequencies, with power supplies at +12V, -12V, -15V, and +5V. A proposed solution involves using an op amp to provide a voltage source output with a gain of approximately -2.67 to map 0-4.5V input to 0 to -12V output, replacing or supplementing the transistor stage. The op amp output, connected via a 10k resistor to the -15V node (input of the LM3080), can drive the node with the desired modulation current. To maintain a current source characteristic and reduce errors from transistor base current, replacing the PNP BJT with a P-channel MOSFET is suggested. Waveform examples confirm the modulation behavior, and the approach allows the modulation amplitude to scale with the control voltage, preventing clipping at low voltages.
