What is a VFT (Variable Frequency Transformer) and how does it work?
291 6
  • #1 21670090
    ebrahim Saadati
  • VFT as a continuously adjustable phase-shifting transformer
    #2 21670091
    Mark Harrington
  • Balanced-to-unbalanced transformer with radial dual windings
    #3 21670092
    Mark Harrington
  • Maths still required for matrix-based VFT software
    #4 21670093
    Mark Harrington
  • #5 21670094
    Mark Harrington
  • #6 21670095
    ebrahim Saadati
  • #7 21670096
    John Steave
A Variable Frequency Transformer (VFT) is a specialized electrical machine used to control power flow between two AC networks operating at different frequencies, either asynchronous or synchronous. It functions as a continuously adjustable phase-shifting transformer, enabling controlled power transfer without the need for harmonic filters or reactive power compensation, unlike back-to-back HVDC converters. The VFT consists of a doubly fed electric machine similar to a vertical shaft hydroelectric generator, with a three-phase wound rotor connected via slip rings to one power circuit and a direct-current torque motor mounted on the same shaft. By adjusting the torque motor's direction, the power flow direction between the two grids can be controlled. The shaft rotation results from frequency differences between the connected networks when no external torque is applied. Limitations include the current-carrying capacity of the slip rings. The VFT was first deployed in 2004 and offers an alternative to traditional synchronous transformers and HVDC links for grid interconnections. Understanding its operation requires knowledge of generator principles, synchronous and asynchronous machine theory, and associated mathematical modeling, including matrix equations and simultaneous equations.
