how to remove noise generated in the inductor of a buck regulator
543 15
How can I stop the audible buzzing or vibration coming from the inductor in my A6213 buck LED driver when I increase LED brightness?
The noise was caused by the PWM dimming signal frequency, not by LED flicker or a faulty layout, and the fix was to set the PWM frequency within the datasheet’s recommended 100 Hz to 2 kHz range; lowering it to 100 Hz removed the noise [#21671996] If the inductor itself is mechanically vibrating, other replies suggest trying a different inductor or damping it with glue/RTV, but the reported resolution was changing the PWM frequency [#21671990] [#21671991]
  • Inductor noise increases with LED brightness
    #1 21671985
    bensen john
  • Datasheet guidance for setting frequency and inductance
    #2 21671986
    John Schmitz
  • Metal enclosure and nearby EMI sources matter
    #3 21671987
    Nick Brackenbury
  • #4 21671988
    John Schmitz
  • #5 21671989
    bensen john
  • Replacing the inductor to stop acoustic noise
    #6 21671990
    Mark Nelson
  • Check regulator frequency, load, and output capacitance
    #7 21671991
    Frank Bushnell
  • Audible hum suggests a mechanically loose inductor
    #8 21671992
    Nick Brackenbury
  • Suggesting a snubber and better noise diagnosis
    #9 21671993
    Steve Lawson
  • Ripple is tolerable in switch-mode LED drivers
    #10 21671994
    Steve Lawson
  • Thermal shutdown and layout may cause flicker
    #11 21671995
    Steve Lawson
  • Lowering PWM frequency to 100 Hz removed inductor noise
    #12 21671996
    bensen john
  • #13 21671997
    Steve Lawson
  • Low-frequency PWM may cause visible flicker
    #14 21671998
    Steve Lawson
  • LED flicker causes stronger biological effects
    #15 21671999
    Steve Lawson
  • #16 21672000
    pradeep kumar
The discussion addresses acoustic noise generated by the inductor in a buck regulator circuit using the Allegro Microsystems A6213 LED driver. The noise manifests as audible vibration or humming from the inductor, increasing with LED brightness. Initial assumptions about electrical noise or LED flicker were clarified to be mechanical vibrations caused by magnetic forces within the inductor. Suggested solutions include verifying the PWM dimming frequency, as the noise was resolved by adjusting the PWM frequency to within the recommended 100 Hz to 2 kHz range per the A6213 datasheet. Additional recommendations include using a toroidal inductor to contain magnetic flux, ensuring proper mechanical fixation of the inductor coil (e.g., epoxy or RTV glue), employing metal shielding to reduce electromagnetic interference, and checking for proper PCB layout and thermal management to avoid thermal shutdown. The discussion also highlights the trade-off of low PWM frequencies causing visible flicker and potential user discomfort. Snubber circuits were mentioned as a solution if the noise were electrical ringing rather than acoustic. The final resolution was frequency adjustment of the PWM dimming signal rather than changing the inductor or circuit layout.
TL;DR: For A6213 LED buck drivers, set PWM dimming between 100 Hz–2 kHz; “adjusting it to 100 Hz removed the noise.” [Elektroda, bensen john, post #21671996] Why it matters: This FAQ helps engineers fix audible inductor noise (coil whine) and avoid flicker or EMI when dimming LED strings with buck regulators.
How do I stop the inductor from making a humming sound on my A6213 buck LED driver?
Lower the PWM dimming frequency into the 100 Hz–2 kHz range. One builder eliminated the hum at 100 Hz. If noise persists, swap to a mechanically robust or different inductor type and add damping compound. These changes target magnetically driven vibration in the coil. [Elektroda, bensen john, post #21671996]
Is the noise electrical ripple or audible coil whine—how can I tell quickly?
Use a scope or a DMM with frequency to check for low‑frequency components besides the switching rate. If LEDs are stable but you hear sound, it’s mechanical vibration. Confirm regulator frequency and inspect for overload or layout faults that add unwanted components. [Elektroda, Frank Bushnell, post #21671991]
Will changing the switching frequency fix audible noise?
Audible coil whine often tracks drive conditions. Changing operating frequency can confirm a mechanical resonance and guide fixes. If whine shifts or disappears, replace the inductor, re‑orient it, or add RTV/epoxy to damp the vibration. “Maybe just put a glob of RTV on it.” [Elektroda, Mark Nelson, post #21671990]
Is 100 Hz PWM dimming safe for visual comfort?
100 Hz sits near the flicker fusion threshold for many people. Some users may notice strobing, fatigue, or headaches, especially in peripheral vision or moving scenes. Consider higher PWM within the device’s recommended dimming range to reduce perceptible flicker. [Elektroda, Steve Lawson, post #21671998]
Could nearby electronics be causing the noise or instability?
Yes. Unshielded inductors can pick up or radiate EMI. Place the circuit in a metal screened enclosure and keep it away from switching supplies, PCs, or displays that operate at similar frequencies. Proper physical placement reduces interference and spurious tones. [Elektroda, Nick Brackenbury, post #21671987]
Would a toroidal inductor help with noise?
A toroid confines magnetic flux and reduces external field coupling. That lowers EMI and can cut acoustic effects from interaction with surroundings. If your current core is open or poorly bonded, moving to a toroid often improves results. [Elektroda, John Schmitz, post #21671988]
What inductor spec should I check besides inductance?
Verify the inductor’s self‑resonant frequency (SRF) exceeds the highest operating frequency. For A6213 designs near 0.5–2 MHz, choose significantly higher SRF to avoid resonance, excess loss, and ringing. Bigger SRF margin improves stability and noise. [Elektroda, Steve Lawson, post #21671993]
Should I add a capacitor across the LEDs to smooth ripple?
Ripple is expected, and some is fine at high switching rates. The A6213 guidance advises against an output filter capacitor across the LEDs for stated reasons. Follow the datasheet layout and ripple targets instead. [Elektroda, Steve Lawson, post #21671994]
Could thermal shutdown be the reason for visible flicker or intermittent noise?
Yes. If the IC overheats, it may cycle, causing flicker or unstable operation. Improve thermal pads and copper area, check current levels, and verify PCB placement per the thermal layout notes to prevent shutdown cycling. [Elektroda, Steve Lawson, post #21671995]
How do I localize exactly which part is making the sound?
Use a short rubber or vinyl tube as a stethoscope. Place one end at your ear and probe components with the other end. When the sound peaks, you’ve found the source and can replace or damp it. [Elektroda, Steve Lawson, post #21671993]
What’s a snubber and when should I try one?
A snubber (RC or RCD) damps switch node ringing that can produce EMI and audible artifacts. If your scope shows overshoot or underdamped ringing, design a snubber for that node before changing major parts. [Elektroda, Steve Lawson, post #21671993]
Give me a quick 3‑step fix for coil whine on a buck LED driver.
  1. Sweep operating conditions to shift frequency; note any change in pitch or level.
  2. Replace the inductor with a different brand or construction and re‑orient it.
  3. Apply RTV/epoxy to mechanically damp the coil and core interface. [Elektroda, Mark Nelson, post #21671990]
Does the A6213 actually switch in the audio band?
No. The intended switching frequency is far above audio, near 500 kHz–2 MHz. Audible noise is typically mechanical resonance or EMI coupling, not the PWM switch rate itself. [Elektroda, Steve Lawson, post #21671993]
Is there a proven field fix from this thread?
Yes. The original poster eliminated the inductor noise by reducing PWM dimming frequency to 100 Hz, within the suggested 100 Hz–2 kHz window. [Elektroda, bensen john, post #21671996]
