2N3904 Transistor Circuit: How to Amplify 0.5–5V Sensor Signal from 1mA to 10mA?
222 7
  • #1 21673086
    Kaushal Patel
  • Use a rail-to-rail op-amp buffer for current drive
    #2 21673087
    Dean Franks
  • #3 21673088
    Richard Gabric
  • #4 21673089
    Kaushal Patel
  • #5 21673090
    Eutex International INC
  • #6 21673091
    Olly Moros
  • #7 21673092
    Kaushal Patel
  • #8 21673093
    Kaushal Patel
A pressure sensor outputs a voltage range of 0.5 V to 5 V with a current of about 1 mA, and the goal is to amplify the current to approximately 10 mA using a 2N3904 transistor powered by a 9 V supply. The main challenge is selecting appropriate resistor values for the transistor circuit. A recommended solution is to use an operational amplifier (op-amp) in a buffer configuration (unity gain) to provide the necessary drive current without altering the voltage signal. A single-supply, rail-to-rail op-amp powered by 9 V is suitable, especially if the sensor output does not reach ground level. For precision applications, choosing an op-amp with low input offset voltage or offset compensation is advised. The discussion clarifies that "amplify current" means increasing the output current capability from 1 mA to 10 mA while maintaining the voltage signal. Further details on resistor calculations for the 2N3904 transistor were not provided, but the op-amp buffer approach was confirmed effective by the original poster.
