SR1660 Schottky Barrier Rectifier SPICE Model Creation from Datasheet Parameters
198 7
  • #1 21674429
    mady b
  • Use a similar Schottky diode model for noncritical applications
    #2 21674430
    richard gabric
  • How to calculate Schottky SPICE parameters from datasheet
    #3 21674431
    mady b
  • Choosing the emission coefficient for a Schottky diode
    #4 21674432
    mady b
  • #5 21674433
    richard gabric
  • #6 21674434
    mady b
  • Emission coefficient is process dependent and approximate
    #7 21674435
    richard gabric
  • Questions on calculating RS and TT from datasheet
    #8 21674436
    mady b
✨ The discussion focuses on creating a SPICE model for the SR1660 Schottky Barrier Rectifier using datasheet parameters. Since no direct SPICE model for the SR1660 is readily available, it is suggested to approximate by using SPICE models of similar Schottky diodes with comparable voltage and current ratings. Key parameters for modeling include saturation current (IS), junction capacitance (CJO), and emission coefficient (N). The emission coefficient for Schottky diodes typically ranges between 1 and 2, but its exact value is manufacturing and process dependent; simulation with values of 1 and 2 is recommended to observe differences. Parameters such as ohmic resistance (RS) and transit time (TT) are often not provided in datasheets and may require estimation or default values. The .model statement syntax varies between SPICE versions, and parameter extraction methods from datasheets exist but may be approximate. Overall, SPICE models for Schottky diodes are approximations, and critical applications may require empirical measurements or breadboarding to refine parameters.
