Meaning and Behavior of Zener Diode Symbol in Circuit Diagrams
246 8
  • #1 21676013
    PAUL IZZO
  • TVS diode clamps supply transients to ground
    #2 21676014
    Kevin Angelo Ma
  • #3 21676015
    PAUL IZZO
  • #4 21676016
    PAUL IZZO
  • #5 21676017
    richard gabric
  • Asymmetric rectifier acts as microwave short protector
    #6 21676018
    Sambath Kumar
  • #7 21676019
    Kevin Angelo Ma
  • #8 21676020
    Vision Electronergy
  • Asymmetric rectifier is two back-to-back diodes
    #9 21676021
    Sambath Kumar
The diode symbol in question represents an Asymmetric Rectifier, also known as a Short Protector, commonly used in high voltage circuits such as microwave ovens. This component consists of two independent diodes connected back-to-back with different peak inverse voltage ratings—approximately 6 kV for the larger diode and 1.5 kV for the smaller one. Unlike Transient Voltage Suppressor (TVS) diodes, which typically have maximum voltage ratings around 440 V and a common cathode symbol, the Asymmetric Rectifier does not conduct under normal operating conditions. It serves to protect high voltage transformers and capacitors by short-circuiting under fault conditions (e.g., a short in the magnetron or high voltage diode), causing the line fuse to blow and preventing further damage. The symbol’s unequal arrows indicate different voltage thresholds in each direction. The device is not a TVS diode or a spark gap, but a specialized high voltage protector designed for asymmetric voltage breakdown and fault isolation in high voltage power supply circuits.
