How to Wire Delay Timer Relay for Automatic Fish Feeder Circuit Like YouTube Example?
372 6
  • Need clearer wiring for daily 10-second feeder timer
    #1 21677833
    Pramod Mani
  • Timer likely needs a dry-contact relay trigger
    #2 21677834
    David Ashton
  • #3 21677835
    David Ashton
  • #4 21677836
    Micheal Brick
  • Connect the + line to the normally open terminal
    #5 21677837
    Aubrey Kagan
  • Need a one-shot trigger for the delay relay
    #6 21677838
    Pramod Mani
  • Use NO output and test trigger behavior
    #7 21677839
    David Ashton
The discussion addresses wiring a 12V delay timer relay for an automatic fish feeder circuit controlled by a 24-hour mains timer. The goal is to activate the feeder for 10 seconds daily at a set time. The main issue is that the delay timer relay remains active and cycles repeatedly during the entire 1-minute activation period of the mains timer, instead of running once for 10 seconds. It is clarified that the delay timer relay requires a brief trigger pulse rather than a continuous 12V supply. The original wiring uses the Normally Closed (NC) relay contact, which causes continuous activation; switching to the Normally Open (NO) contact is recommended. Additionally, the 24-hour mains timer output should trigger the delay timer relay via a relay coil and its Normally Open contacts to provide a short circuit trigger, as the timer may not respond correctly to a direct 12V input. Testing by momentarily shorting the trigger line to +12V can verify correct timer operation. A relay from an automotive store can be used to interface the mains timer with the 12V delay timer relay. A wiring diagram is suggested for clarity.
