Is 600VA 230/40VAC Transformer Sufficient for 240W 24VDC SCR Thyristor Bridge Output?
384 3
  • Transformer undersized for 24 V at 10 A load
    #1 21678390
    Deepak P
  • Load test and check voltage drops stage by stage
    #2 21678391
    Rick Curl
  • Scope test and diode substitution to isolate rectifier issue
    #3 21678392
    David Ashton
  • Use diode rectifiers and measure AC ripple at output
    #4 21678393
    PeterTraneus Anderson
