Homebrew PCB Cost vs JLCPCB, PCBWay, Sodium Persulphate, Ferric Chloride in 2024
426 15
Is it still worth making a few PCBs at home, or should I use cheap PCB fab services when I only need a handful of boards?
Yes for quick, simple or artwork-only one-off boards, but for most other cases the cheap PCB houses mentioned were better value and far less hassle [#21678402][#21678405][#21678416] One user compared a 98x77 mm board and found PCBShopper prices as low as £1.60 each for 5 (£8 total), while home processing a 4"x6" board with transparency, developer, etchant and UV board cost nearly £6 for only two boards [#21678405] The main homebrew advantages were immediate turnaround, making boards from old artwork without Gerbers, and keeping control of simple single-sided prototypes [#21678402][#21678405] The main disadvantages were labor, drilling, double-sided alignment, touch-up work, and the mess/handling of ferric chloride; several posters said they would send anything complex or SMT-heavy out to fab houses [#21678402][#21678407][#21678416] If you stay with home etching, ammonium/persulphate was suggested as a cleaner alternative to ferric chloride, and one poster said a 500 ml bottle had lasted a year; caustic soda developer at 7 g/L was also mentioned [#21678402] Low-cost fabs like Elecrow and PCBWay were reported as coming in around £8 for 5 double-sided 10x10 cm boards, often with delivery in about 8 days, though larger sizes or rush shipping change the price [#21678408][#21678413][#21678416]
  • Home PCB etching costs versus cheap fab houses
    #1 21678401
    Ian Stedman
  • Home PCB etching tips and cheap developer mix
    #2 21678402
    David Ashton
  • Request for rough postcard-size two-sided PCB pricing
    #3 21678403
    Graham Rounce
  • USA-centric PCB manufacturer price comparison link
    #4 21678404
    Elizabeth Simon
  • Home etching costs nearly £6 for two PCBs
    #5 21678405
    Ian Stedman
  • #6 21678406
    Ian Stedman
  • DIY PCB etching not worth the time
    #7 21678407
    Alan Winstanley
  • Elecrow pricing and turnaround for 10x10 boards
    #8 21678408
    Basement Boy
  • Home PCB kit enables boards in hours
    #9 21678409
    Chip Fryer
  • Milling drawbacks and why cheap fab wins
    #10 21678410
    Basement Boy
  • Zippy board milling and surface mapping notes
    #11 21678411
    Chip Fryer
  • #12 21678412
    Ian Stedman
  • Elecrow and DirtyPCBs as low-cost options
    #13 21678413
    Andrew Gale
  • #14 21678414
    Mike Hibbett
  • Elecrow rush order costs about £5 per board
    #15 21678415
    Chip Fryer
  • Home etching still works for simple through-hole boards
    #16 21678416
    Mike Hibbett
The discussion compares homebrew PCB fabrication using ferric chloride and sodium persulphate etchants with commercial PCB manufacturing services like JLCPCB, PCBWay, Elecrow, and others in 2024. Home etching remains popular for prototyping and one-off boards due to the hands-on control and immediacy, but challenges include chemical handling, limited etchant shelf life (notably sodium persulphate), difficulty achieving fine track resolution, double-sided board complexity, and labor intensity. Ferric chloride is noted for long shelf life but is messy and corrosive, while sodium persulphate is less noxious but has a shorter usable life. Commercial PCB services offer competitive pricing, especially for small batches, with examples such as Elecrow providing 5 double-sided boards (~10x10 cm) for under £10, and PCBWay delivering boards within 8 days at low cost. Some users highlight the convenience and quality of professional fabrication, especially for complex or surface-mount designs, while others maintain home etching for quick prototypes or simple through-hole designs. Additional considerations include the cost-benefit analysis of time versus money, the use of UV exposure and developer chemicals (e.g., sodium hydroxide), and the availability of PCB milling machines, which remain costly and less practical for hobbyists. Panelization services like dirtypcbs.com are mentioned for cost efficiency. Overall, the consensus suggests that while homebrew PCB making is rewarding and suitable for simple or urgent tasks, commercial PCB fabrication is increasingly affordable and preferable for complex, multi-layer, or higher-quality boards.
TL;DR: For hobby PCBs, £8 for 5 double‑sided 10×10 cm and ~8‑day delivery is common; “I haven’t looked back.” [Elektroda, Basement Boy, post #21678408] Why it matters: This FAQ helps makers decide when to etch at home vs. order from budget fabs, with real prices, timelines, and pitfalls—ideal for one‑offs, prototypes, and learning.
Is making PCBs at home still worth it in 2024 versus JLCPCB/PCBWay?
For prototypes and one‑offs, home etch can be faster if your setup is ready. But recent orders show ~£5 per board with rush, delivered in under a week, narrowing the DIY cost advantage. If appearance and double‑sided reliability matter, ordering wins. [Elektroda, Chip Fryer, post #21678415]
How much does a 10×10 cm double‑sided board cost, and how fast can I get it?
Expect about £8 for five boards with standard shipping deals. One user ordered on a Sunday and received boards eight days later. This fits typical hobby timelines without DIY mess or drilling. It’s a strong value for repeatable results and spares. [Elektroda, Basement Boy, post #21678408]
I only have artwork, not Gerbers—can fabs still make my board?
No. Low‑cost fabs require Gerber files. Artwork or PDFs won’t suffice. For legacy magazine projects with only artwork, DIY etching is the practical route. “You get a professional finish” when you do have Gerbers to submit. [Elektroda, David Ashton, post #21678402]
What trace/space can I reliably achieve at home?
With good transparencies, dialed exposure, and fresh chemicals, 0.010"/0.254 mm trace and gap are attainable. Set conservative design rules and verify with a small coupon before full boards. Proper UV exposure reduces pinholes and undercut. [Elektroda, Ian Stedman, post #21678405]
Which etchant should I choose: sodium persulfate or ferric chloride?
Sodium persulfate is cleaner and less noxious but degrades within weeks. Ferric chloride stores for years and remains effective but is messy and corrosive. Factor storage, ventilation, and disposal into your choice. [Elektroda, Ian Stedman, post #21678401]
What does a home‑etched board actually cost per piece?
A 4×6" photoresist board with transparency, developer, and etchant runs about £6 in consumables. Efficient panel use can halve per‑design cost if you split the board. Compare that to ~£1.60–£5 per ordered board in examples. [Elektroda, Ian Stedman, post #21678405]
Are double‑sided DIY boards practical?
They work but raise failure risk and labor. One maker reported two successes out of three attempts. Vias, alignment, and through‑plating complicate builds. Many switch to fab houses for double‑sided reliability and solder mask. [Elektroda, Ian Stedman, post #21678405]
Should I mill PCBs instead of etching?
Milling avoids wet chemistry but brings dust, noise, slower runs, and frequent bit wear. Economy copper‑clad can be uneven, causing trace depth issues. Post‑mill cleanup to remove whiskers is mandatory to prevent shorts. [Elektroda, Basement Boy, post #21678410]
Can I get professional boards back in under a week?
Yes. DHL or rush services can deliver in less than a week, at added cost. Users report rapid turnarounds that suit pilot runs and urgent testing. This rivals the total time of DIY once you include drill and cleanup. [Elektroda, Andrew Gale, post #21678413]
What is PCBShopper and why use it?
PCBShopper is a price‑comparison site for PCB fabrication. Enter size and quantity to see current deals across vendors. It helps quantify whether home etch beats ordering for your specific design and schedule. [Elektroda, Ian Stedman, post #21678401]
How do I develop and expose photoresist cheaply at home?
Try this three‑step flow:
  1. Print on laser transparency; disable Economy mode.
  2. Expose coated boards; one minute in strong sun for commercial stock.
  3. Develop with sodium hydroxide at ~7 g/L; etch and rinse. “Takeaway containers” work as trays. [Elektroda, David Ashton, post #21678402]
Can I get a transparency made without buying a laser printer?
Yes. Bring laser‑safe film to a copy shop and ask them to print your artwork. Ensure they use the correct film type. Thicker, denser prints improve exposure quality and reduce pinholes in fine features. [Elektroda, David Ashton, post #21678402]
Is panelization a good way to cut costs for small projects?
Yes. Services like DirtyPCBs let you panelize several small designs into a 10×10 cm area. One report: about $25 delivered for roughly eleven copies of the panel, boosting value across multiple sub‑boards. [Elektroda, Andrew Gale, post #21678413]
When does DIY beat ordering from a fab?
DIY wins for immediate fixes, quick winter projects, and simple single‑sided boards. No shipping delay and full control aid fast iteration. Complex boards with many holes favor outsourcing due to time savings. [Elektroda, Ian Stedman, post #21678406]
Any drilling or finishing gotchas with homebrew boards?
Drilling is the time sink. Large hole counts slow builds and increase breakage risk. Plan pad sizes to ease soldering and consider tinned wire jumpers for layer swaps. Surface‑mount reduces drilling workload notably. [Elektroda, Ian Stedman, post #21678406]
What do experienced hobbyists say about switching to fabs?
Several moved to low‑cost Chinese fabs for SMD and repeatability. One said, “I will never do [double‑sided at home] again,” after getting boards back in eight days. Reliability and finish drove the change. [Elektroda, Mike Hibbett, post #21678416]
