What’s the best language to learn for embedded systems — C, C++, or Python?
510 13
What language should I learn first for embedded systems programming?
C is the safest default to learn for embedded systems, with C++ also valuable; Python is easier to learn and faster to write, but it is generally slower and has less embedded support [#21678828][#21678833] If you want to be employable as an embedded programmer, you really need to know C, because low-level code is often written in C even when C++ is used for higher-level parts [#21678833] Some schools even teach C++ first and then C, since learning C from C++ is largely learning what parts you do not use [#21678833] C also helps with efficiency and hard-real-time work because it is close to a powerful assembly-language preprocessor and makes performance easier to reason about [#21678840] Python can still be useful when raw speed is not critical, but it is not the primary choice for core embedded firmware [#21678828]
  • C offers speed, C++ power, Python ease of use
    #1 21678827
    Max Maxfield
  • C or C++ remain best for embedded systems
    #2 21678828
    Elizabeth Simon
  • Embedded Pascal and Basic as safer C alternatives
    #3 21678829
    Conrad Mannering
  • #4 21678830
    Justin Spencer Mamaradlo
  • #5 21678831
    Max Maxfield
  • #6 21678832
    Max Maxfield
  • C is essential for embedded employment
    #7 21678833
    Elizabeth Simon
  • #8 21678834
    Max Maxfield
  • Languages supporting 32-bit to 64-bit multiply
    #9 21678835
    PeterTraneus Anderson
  • #10 21678836
    Elizabeth Simon
  • #11 21678837
  • #12 21678838
    Conrad Mannering
  • #13 21678839
    Mike Hibbett
  • #14 21678840
    Mike Hibbett
The discussion evaluates the suitability of C, C++, and Python for embedded systems programming. C is favored for producing small, fast, and efficient code with low-level hardware access, though it allows potentially unsafe operations. C++ offers powerful object-oriented features but has a steeper learning curve; some curricula introduce C++ before C to ease learning. Python is praised for ease of use and rapid development but generally lacks the performance and embedded support of C/C++. Alternatives like embedded Pascal and BASIC compilers for AVR chips were mentioned, highlighting strong typing and ease of use but less common adoption. The importance of algorithm design over language choice was emphasized, though practical employment in embedded systems typically requires proficiency in C/C++. Handling 64-bit arithmetic on 32-bit processors was discussed, noting compiler-dependent support for 64-bit types like "long long int" and the use of assembly for precise timing and performance estimation. Overall, C and C++ remain the dominant languages for embedded development due to their efficiency and hardware control capabilities.
TL;DR: For embedded careers, start with C/C++; use Python for fast prototyping. 64/128‑bit math crops up, and “execution speed can be estimated before building hardware.” [Elektroda, Anonymous, post #21678837]
Why it matters: This FAQ helps students, hobbyists, and engineers choose the right language and tools for embedded systems.
What’s the best language to learn first for embedded systems?
Learn C first, then C++. C maps closely to hardware and toolchains are mature. C++ adds safer abstractions and useful patterns. Python is great for prototyping, but MCU support and performance trail C/C++. Choose based on project constraints and platform. [Elektroda, Anonymous, post #21678827]
Which language do employers actually ask for in embedded jobs?
C is the baseline. Many teams model algorithms elsewhere, then port to C/C++ for deployment. Some programs teach C++ first, then C, to show what not to use on constrained targets. “You really need to know C.” [Elektroda, Anonymous, post #21678833]
Is algorithm choice more important than language choice?
Yes. Good algorithms dominate outcomes in performance and reliability. As one expert put it, “the underlying algorithm…is most important, not the actual language used.” Design first, then implement in the most suitable language. [Elektroda, Anonymous, post #21678830]
Is C really faster and smaller than Python on microcontrollers?
Typically, yes. C compiles to tight machine code and exposes memory control. Python prioritizes developer speed and readability, which adds runtime overhead. For real‑time or low‑power designs, C/C++ usually win on throughput and size. [Elektroda, Anonymous, post #21678827]
How do I decide between C and C++ on an MCU?
Use C for bare‑metal drivers and critical paths. Use a constrained subset of C++ for safer types, RAII, and templates where they reduce code and bugs. Many teams mix both, keeping low‑level code in C. [Elektroda, Anonymous, post #21678828]
Can I use Pascal or BASIC for embedded projects?
Yes, niche compilers exist. Pascal offers strong typing and avoids heavy pointer work. Some BASIC compilers for AVR yield code sizes comparable to C. Evaluate ecosystem and vendor tool support before committing. [Elektroda, Anonymous, post #21678829]
Why do some engineers still write assembly in embedded?
Assembly helps prove timing and size before hardware arrives. It enables precise control over instruction sequences. One engineer noted you can estimate execution speed pre‑hardware for hard real‑time needs. [Elektroda, Anonymous, post #21678837]
How do I multiply two 32‑bit integers and keep a 64‑bit result in C/C++?
Cast operands to 64‑bit types, multiply, and store in a 64‑bit variable (e.g., long long or int64_t). Note: availability and exact sizes can be compiler dependent on 32‑bit targets. [Elektroda, Anonymous, post #21678836]
Is there a quick way to choose a language for my embedded project?
Try this: 1. Define real‑time, memory, and power limits. 2. Map drivers and critical code to C; use C++ for safer structure if allowed. 3. Prototype high‑level logic in Python, then port hot paths to C/C++. [Elektroda, Anonymous, post #21678827]
What is Tuya?
Tuya is a global AI/IoT cloud platform and ecosystem for building and managing connected products, offering SDKs, device OS, and cloud services. “GLOBAL AI CLOUD PLATFORM SERVICE PROVIDER.” ["About Tuya | Tuya Smart"]
What is an Arduino Nano?
Arduino Nano is a compact microcontroller board in the Nano family, used for breadboard‑friendly embedded projects and available with multiple MCU options. See Arduino’s Products overview for the Nano lineup. ["Arduino Hardware — Products"]
What is OpenBeken?
OpenBeken is open‑source firmware replacing Tasmota/ESPHome on BK72xx and similar chips. It supports OTA updates, MQTT/Home Assistant, scripting, and multi‑relay control. Useful for Tuya‑based devices. ["GitHub - codekow/OpenBeken"]
What is CAN bus?
CAN bus is an automotive/industrial serial bus standard (ISO 11898). Classic CAN runs up to 1 Mbit/s; CAN FD up to 8 Mbit/s. It enables prioritized, reliable ECU communication over differential wiring. ["CAN bus"]
Is starting with C++ then learning C a good strategy?
Yes. Teaching C++ first can highlight safer constructs and then show which features to avoid on constrained systems when moving to C. Some programs use this pathway successfully. [Elektroda, Anonymous, post #21678833]
Any edge cases I should watch when doing big‑integer math on embedded targets?
Yes. 64‑bit types on 32‑bit MCUs may rely on compiler extensions; performance varies. Verify type sizes, promotion rules, and library support before relying on 64‑bit math in critical loops. [Elektroda, Anonymous, post #21678836]
