Clear glass panel 27x34cm with gold wires, 3-core cable, 9-pin IDC—what is this?
183 6
  • Identifying a glass panel with embedded wire grid
    #1 21679992
    Joe Farr
  • Suggesting multimeter tests to identify the panel
    #2 21679993
    David Ashton
  • #3 21679994
    EEWeb
  • #4 21679995
    Joe Farr
  • Suggesting a serial touchscreen overlay test
    #5 21679996
    David Ashton
  • #6 21679997
    Joe Farr
  • RS232 touchscreen needs proper driver and power
    #7 21679998
    David Ashton
A user discovered two clear glass panels measuring 27 x 34 cm, each consisting of two glass layers with fine gold-colored wires arranged in a sawtooth pattern and around the edges, connected via a three-core cable terminating in a 9-pin female IDC connector. The panels are labeled "viewing face" and have a marking "2003/1577" etched on the edge. An epoxy section at the top edge houses possible electronics. Speculation suggests the panels could be electroluminescent backlights, solar panels, heating elements, or more likely, transparent touchscreens designed to overlay other displays. The 9-pin IDC connector and cable might interface with a serial (RS232) port, requiring specific drivers to function. Testing with a multimeter or oscilloscope alone may not reveal activity without proper power and communication signals. The user was advised to attempt connection via a serial port using terminal software to detect any data output when touching the panel, though decoding would require appropriate drivers. No brand or model information was identified.
