How to Design a Dual Pulse LED Flasher Circuit Using NE555 or Similar Timer ICs?
462 8
  • #1 21681531
    ero kasio
  • Need more definition of timing requirements
    #2 21681532
    Aubrey Kagan
  • Suggesting a 74HC154 counter-based LED flasher
    #3 21681533
    David Ashton
  • LED flashes driven by one 8-pin timer IC
    #4 21681534
    ero kasio
  • #5 21681535
    David Ashton
  • #6 21681536
    sophia red
  • #7 21681537
    ero kasio
  • #8 21681538
    Aubrey Kagan
  • #9 21681539
    David Ashton
The discussion focuses on designing a dual pulse LED flasher circuit using timer ICs like the NE555 or similar devices. The original query seeks a method to generate two distinct pulses within one period, resembling a waveform with multiple pulses. Suggestions include exploring "pulse swallowing" techniques and using rate multipliers such as the CD4089, which can produce multiple pulses per cycle, though output specifics are uncertain. Another approach involves employing a 4-bit binary counter with a 1-to-16 line decoder (e.g., 74HC154) to sequence LED flashes by selectively activating outputs and resetting the counter to achieve the desired timing. The possibility of using non-programmable ICs, including custom or irregular Chinese ICs, was discussed, with some skepticism about their exact nature due to obscured markings. Linear Technology (now Analog Devices) Timerblox series, programmable by resistor values rather than capacitors, were mentioned as a potential avenue, though none are confirmed to provide the required pulse pattern. The conversation highlights the complexity of generating multiple distinct pulses within a single period using standard timer ICs and suggests that multiple ICs or microcontrollers might be necessary for precise control.
