Converting 1500W 120VAC Space Heater to 48VDC: Resistance and Current Calculations
402 16
Can I run a 120 VAC 1500 W space heater directly from 48 VDC, and what current and heat output would I get?
You can apply 48 VDC to the heater element, but a 120 V, 9.6 ohm element will not deliver 1500 W at 48 V; it will draw about 5 A and produce about 240 W [#21681553] To get 1500 W at 48 V, the load needs to be about 1.536 ohms, so the existing element would have to be reworked into multiple parallel sections; for example, six equal sections in parallel would be about 1.6 ohms and roughly 1440 W [#21681551] The heating element itself does not care whether the supply is AC or DC, but the fan motor may need replacement because an AC fan will not run on DC [#21681549] The nichrome wire’s resistance will change a little with temperature, but that effect is small and does not materially change the power estimate [#21681559] Because 48 V at the higher power level means high current, you also need very heavy wiring and a supply that can source it safely [#21681553]
  • Resistance stays the same on DC heater load
    #1 21681548
    Sid Connor
  • Recommend lower-voltage heating element or split existing one
    #2 21681549
    Rick Curl
  • Asking what happens when 48 VDC is applied to a 120 VAC heater
    #3 21681550
    Sid Connor
  • Corrected 48V heater resistance and power estimate
    #4 21681551
    David Ashton
  • #5 21681552
    Sid Connor
  • 48V heater needs much lower resistance element
    #6 21681553
    Elizabeth Simon
  • 48V operation would greatly reduce heater output
    #7 21681554
    David Ashton
  • Four 12V car heaters in series for 48V heating
    #8 21681555
    Elizabeth Simon
  • #9 21681556
    David Ashton
  • Testing a 120 V heater on 48 VDC
    #10 21681557
    Sid Connor
  • Suggesting a lower-power 48V heater or 12V battery tap
    #11 21681558
    David Ashton
  • Nichrome resistance change has little effect at 48V
    #12 21681559
    David Ashton
  • Trying a low-cost electric heater instead of propane
    #13 21681560
    Sid Connor
  • #14 21681561
    Rick Curl
  • Questioning the 10A at 48V rating
    #15 21681562
    David Ashton
  • #16 21681563
    Sid Connor
  • Recommend four 48V fan heaters instead of one conversion
    #17 21681564
    David Ashton
The discussion addresses converting a 1500W 120VAC space heater to operate on a 48VDC system, focusing on resistance, current, and power calculations. The original heater has a resistance of approximately 9.6 ohms, drawing 12.5A at 120VAC for 1500W output. Applying 48VDC directly to the same element results in a lower current (~5A) and significantly reduced power (~240W), not the intended 1500W. To achieve 1500W at 48V, the heating element resistance must be reduced to about 1.5 ohms, which could theoretically be done by dividing the element into multiple parallel segments, though this may be impractical depending on the heater type (e.g., IR heaters with coiled wire in glass tubes). The fan motor in the heater, typically designed for AC, will not operate on DC and requires replacement with a DC-compatible motor or elimination if using fanless IR heaters. Alternative solutions include using multiple 12V 150W car heaters wired in series to approximate 48V and achieve around 600W, which may be sufficient for a golf cart heater application. Commercial 48V heaters exist but are costly and often lower wattage (~480-500W). The internal resistance of nichrome wire varies with temperature and voltage, but this effect is minor in practical terms. Battery capacity and current draw at 48V (potentially over 30A for 1500W) are critical considerations for golf cart applications. Experimentation with a cheap 120VAC heater powered at 48VDC is planned to observe real-world performance.
TL;DR: 48V across 9.6Ω draws 5A (~240W). "At 48V, the same 9.6 ohm heating element will only draw 5 amps … 240 W." [Elektroda, Anonymous, post #21681553] Why it matters: DIYers ask how to run a 120VAC 1500W space heater from a 48VDC pack (e.g., golf cart) without wasting money or frying parts.
Can I run a 120VAC 1500W space heater on 48VDC directly?
Yes, but power drops sharply. With the original ~9.6Ω element, 48V gives about 5A and ~240W heat, not 1500W. [Elektroda, Anonymous, post #21681553]
Why isn’t the element’s resistance still 9.6Ω when cold?
Nichrome’s resistance changes with temperature. At 48V it runs cooler, so resistance falls slightly. Expect ~250–260W, not a big jump. [Elektroda, Anonymous, post #21681559]
Do heating elements care about AC vs DC?
No. The element is resistive, so AC or DC doesn’t matter for heat. Replace or adapt any AC fan motor separately. [Elektroda, Anonymous, post #21681549]
What about the built‑in fan motor on AC heaters?
AC induction fans won’t run on DC. Replace with a DC fan, or if it’s a brush motor, you may integrate it differently. [Elektroda, Anonymous, post #21681551]
How can I get close to 1500W from 48V safely?
Reduce total resistance to ~1.536Ω. One method is splitting the original element into six equal parts and wiring them in parallel. [Elektroda, Anonymous, post #21681551]
What wire and current should I plan for at 1500W/48V?
Budget ~31.25A continuous and use heavy-gauge wiring rated accordingly. Keep runs short and connections tight. [Elektroda, Anonymous, post #21681553]
Is using an inverter to power the 120VAC heater from 48VDC smart?
It works, but it’s an expensive route for simple resistive heating. Direct 48V solutions are more efficient and cheaper. [Elektroda, Anonymous, post #21681554]
What’s a practical 48V heater build without rewinding elements?
Use four identical 12V/150W car heaters in series for 48V/600W. Ensure they all switch on together. [Elektroda, Anonymous, post #21681555]
How do I wire four 12V heaters in series on 48V?
  1. Verify all four units are identical and set to HEAT.
  2. Wire: 48V+ → H1 → H2 → H3 → H4 → 48V−.
  3. Use one master switch/relay so all power on together. [Elektroda, Anonymous, post #21681555]
What failure should I watch for with series‑wired heaters?
If one unit is set to FAN‑only, most of the 48V appears across remaining heaters and can burn a fan out. [Elektroda, Anonymous, post #21681564]
Will high heater power drain my traction batteries too fast?
Yes. Large loads can shorten range. Users warn 1500W may leave you walking if used continuously. [Elektroda, Anonymous, post #21681557]
Can I run a 12V heater from one battery in a 48V pack?
It works electrically but unbalances the pack. Rotate which battery you tap or avoid this method. [Elektroda, Anonymous, post #21681558]
Are IR space heaters better for this conversion?
Tapping IR elements is impractical. Without major rework, power at 48V still falls to ~240W on a 9.6Ω element. [Elektroda, Anonymous, post #21681554]
