How to Make a 4-Pin Crystal Oscillator Generate a Stable Oscillating Waveform
348 8
  • #1 21681821
    david lopez
  • #2 21681822
    Mark Rackin
  • #3 21681823
    david lopez
  • Need an oscilloscope to verify oscillator frequency
    #4 21681824
    Aubrey Kagan
  • LED test suggests 100 MHz oscillator is outputting current
    #5 21681825
    david lopez
  • Enable pin test and 555 timer suggestion
    #6 21681826
    Elizabeth Simon
  • #7 21681827
    Aubrey Kagan
  • CD4060 with 32.768 kHz crystal for LED blink
    #8 21681828
    David Ashton
  • #9 21681829
    Aubrey Kagan
A user seeks guidance on how to make a 4-pin crystal oscillator generate a stable oscillating waveform, specifically attempting to drive an LED directly from a 100 MHz oscillator. Responses clarify that the oscillator output likely cannot provide sufficient current to visibly blink an LED at such a high frequency, and direct LED connection risks damage without a current-limiting resistor. The human eye cannot perceive blinking at frequencies above approximately 40-60 Hz, so a frequency divider circuit is necessary to reduce the oscillator frequency to a visible blinking rate. Suggested solutions include using IC frequency dividers such as the 74F161 (divide by 16) or the CD4060 with a 32.768 kHz watch crystal for practical LED blinking applications. The CD4060 circuit requires specific capacitor and resistor values (22 pF capacitors, 10K-100K resistor), proper pin grounding (reset pin 12), and power supply considerations (max 12V). Alternative simpler methods include using blinking LEDs that do not require external oscillators or ICs. The discussion emphasizes that using a 100 MHz crystal oscillator to blink an LED is overcomplicated and impractical without additional circuitry.
