How to Identify and Name an Unknown Electronic Circuit for Further Analysis
264 10
What is this transistor circuit topology called so I can search for its analysis?
The circuit is a common-emitter stage feeding a common-base stage, with an emitter follower at the output; Q1 and Q2 together form a folded cascode amplifier [#21682304] [#21682305] It may also be described as a video amplifier, since it is aimed at AC bandwidth rather than DC precision [#21682305] One reply notes it is useful for amplifying signals from magnetic disk or tape heads and compares it to the TI TL592B differential video amplifier [#21682305] The circuit has no feedback loops, so it should be straightforward to analyze [#21682309] Another reply suggests the shown component values make it look more like a teaching/demo circuit than a practical real-world design [#21682304] [#21682309]
  • #1 21682303
    Ryan Mco
  • #2 21682304
    David Ashton
  • Folded cascode video amplifier with no feedback
    #3 21682305
    PeterTraneus Anderson
  • #4 21682306
    Ryan Mco
  • #5 21682307
    Ryan Mco
  • #6 21682308
    Ryan Mco
  • Cascode reduces R1 voltage to prevent oscillation
    #7 21682309
  • #8 21682310
    Ryan Mco
  • #9 21682311
    Jack Grubbs
  • #11 21682313
    Arise Electronics
The discussed circuit consists of a common-emitter amplifier stage (Q1), followed by a common-base amplifier stage (Q2), and concludes with an emitter follower stage (Q3). Together, Q1 and Q2 form a folded cascode amplifier, characterized by the use of NPN and PNP transistors, which enhances AC bandwidth and is typically applied in video amplification, such as signals from magnetic disk or tape heads. The circuit lacks feedback loops, simplifying analysis. The common-base stage is used to reduce voltage gain in the first stage and improve frequency response by minimizing the AC voltage across certain resistors, a key feature of the cascode configuration. The emitter follower provides buffering. The voltage gain of the first stage is small due to the cascode connection. For analysis, it is recommended to consider transistor voltages and currents with idealized assumptions (infinite beta, zero base-emitter voltage) and to understand the operation conceptually rather than relying solely on equations. Several educational resources and tutorials on common-emitter, common-base, common-collector amplifiers, and cascode configurations were suggested for deeper understanding. The Texas Instruments TL592B differential video amplifier was referenced as a comparable commercial example used in antenna signal amplification.
