Does a PC overwrite all bits when updating memory from 1100 to 1111, even if some match?
357 14
When a computer writes a new 4-bit value to memory, does it rewrite every bit even if some bits are already the same, or does it leave matching bits untouched?
It rewrites the memory/register location with the new value; it does not preserve old bits just because they already match. A write can simply load the new 4-bit value in one operation, which is the efficient approach, instead of comparing each bit and rewriting only the different ones [#21682614] A storage bit only remembers the most recently written value, so if you write 1 to a bit that already holds 1, the logical value stays 1, but the previous value is still replaced by the new write [#21682615][#21682623] If the new value is different, the write mechanism flips that bit to the new state; if it is the same, the result is still the same stored value [#21682615][#21682623]
  • Memory write overwrites all bits, even unchanged ones
    #1 21682611
    Ryan Mco
  • #2 21682612
    Ryan Mco
  • #3 21682613
    Max Maxfield
  • Memory writes overwrite all bits unconditionally
    #4 21682614
    Max Maxfield
  • Write operation fully replaces stored bit value
    #5 21682615
    John Beetem
  • Switch closure equalizes both sides at 5 V
    #6 21682616
    Ryan Mco
  • Voltage is measured relative to a common reference
    #7 21682617
    Max Maxfield
  • #8 21682618
    Max Maxfield
  • #9 21682619
    Daniel Bliss
  • #10 21682620
    Ryan Mco
  • Clarifying whether bits are overwritten or retained
    #11 21682621
    Ryan Mco
  • Request for a diagram explaining register updates
    #12 21682622
    Ryan Mco
  • Register bits store only the latest written value
    #13 21682623
    John Beetem
  • Need to build a basic analog electronics foundation
    #14 21682624
    Max Maxfield
  • Recommend starting with online electronics tutorials
    #15 21682625
    Elizabeth Simon
The discussion addresses whether a PC or memory system overwrites all bits when updating stored data, even if some bits remain the same. The example given is updating a 4-bit memory location from 1100 to 1111. It is clarified that memory bits do not selectively avoid rewriting bits that match the new data; instead, the write operation overwrites all bits regardless of their previous state. Each memory or register bit stores its current value with minimal power and uses a stronger write mechanism to replace the old value with the new one. Writing a bit that is already set to the desired value still involves overwriting, though the energy difference is minimal. Capacitor-based memory cells, such as those in DRAM, require periodic refreshing because capacitors leak charge, and writing a new value recharges or discharges the capacitor accordingly. The concept is analogous to a switch or voltage line where the voltage level is maintained or changed as needed. The discussion also emphasizes the importance of foundational electronics knowledge for understanding these concepts and recommends systematic learning resources.
TL;DR: PCs overwrite the entire word in one clock cycle; "the computer simply loads the new 4-bit 1111 value." Matching bits are re-driven but unchanged. This FAQ explains writes, registers, and refresh so you can debug or optimize code. [Elektroda, Anonymous, post #21682614]
Why it matters: Understanding word writes vs per-bit updates helps you reason about speed, power, and data integrity in real systems.
When updating 1100 to 1111, does the PC rewrite matching bits (the leading 11)?
It writes the entire word in one go. Matching bits are simply driven to the same level again, which costs little and is fast. The alternative—checking and writing bit-by-bit—takes multiple operations and more time. Designers choose whole-word writes for speed. [Elektroda, Anonymous, post #21682614]
Is writing 11 to an existing 11 wasteful or harmful?
No. The write driver reasserts the same level and the storage keeps it. Energy for a non-flip is minimal, and no extra wear occurs in standard logic/register writes. "The write is much stronger... so the new value overwrites the old value." [Elektroda, Anonymous, post #21682615]
Does memory first clear to 0000 before writing 1111?
No. Typical logic/register writes drive the desired value directly. The old contents don’t need a separate erase step; the stronger write circuitry sets the new state and the cell then holds it. [Elektroda, Anonymous, post #21682615]
What is a register in this context?
A register is a small set of storage bits inside a processor or device. Each bit remembers the most recently written value. The write mechanism overrides any previous state; the holding mechanism then maintains it with low power. [Elektroda, Anonymous, post #21682615]
What happens electrically if I write a 1 to a bit that already stores 1?
The logic level remains 1. The write driver briefly reinforces that state, but no logical change occurs. For capacitor-based storage, a written 1 simply refreshes the charge representing 1. [Elektroda, Anonymous, post #21682623]
Do some memory cells need refresh, and what fails if you skip it?
Yes. Capacitor-based cells leak charge and require periodic refresh. If refresh lapses, bits drift and data decays, causing corruption. This is an expected failure mode for charge-storage cells. [Elektroda, Anonymous, post #21682623]
Why do designers prefer whole-word writes over per-bit updates?
Whole-word writes take one cycle and save power versus multiple compare-and-write steps. In the 4-bit example, 2 of 4 bits differ (50%), yet one operation updates all. Fewer cycles improve latency and efficiency. [Elektroda, Anonymous, post #21682614]
Can software update only the bits that change?
Yes, if the hardware interface allows it. Basic approach: 1) Read old value. 2) Compare with new value. 3) Write back only the targeted fields. This costs extra cycles and logic versus a single word write. [Elektroda, Anonymous, post #21682614]
Is there an initial erase to zero when writing in CPU registers?
No separate erase is required. The act of writing directly forces the desired value, replacing the previous state immediately. The storage then passively holds the new value. [Elektroda, Anonymous, post #21682615]
What is a flip‑flop, simply?
A flip‑flop is a circuit that stores one bit (0 or 1) until a write event changes it. It exemplifies the idea that the newest write replaces prior values, which are not remembered. [Elektroda, Anonymous, post #21682623]
How should I think about voltage when two 5 V nodes are connected?
Use a common reference (ground). If both nodes are 5 V relative to ground and you connect them, any point along the conductor remains 5 V relative to ground. No net push exists between equal potentials. [Elektroda, Anonymous, post #21682617]
What’s a supportive path to learn these topics from scratch?
Study fundamentals in a structured way. Start with DC circuits tutorials and foundational texts, or low‑cost courses with peers. Building basics first makes advanced questions clearer and more productive. [Elektroda, Anonymous, post #21682625]
Is it okay to ask beginner questions like this?
Yes. Curiosity is vital. Still, building a solid foundation prevents confusion and accelerates progress. As one mentor put it, you must learn to walk before you can run. [Elektroda, Anonymous, post #21682624]
