How Does a Dependent Voltage Source Physically Sense and Respond to Controlling Voltage?
375 10
How does a dependent voltage source physically sense the controlling voltage in a circuit, and is it a real device or just a model?
A dependent voltage source is usually just a circuit model, not a separate physical device that “knows” or senses anything [#21682681] The source does not magically receive the controlling voltage; circuit behavior is determined by physical laws such as Ohm’s law and Kirchhoff’s laws [#21682674] In the same way transistor models use dependent sources, the dependent source is there to represent overall behavior more simply, not to imply a real battery-like part with awareness [#21682683][#21682681]
  • Dependent source senses control voltage through circuit connections
    #1 21682673
    Ryan Mco
  • Dependent sources follow circuit laws, not magic
    #2 21682674
    David Ashton
  • How a dependent source senses the controlling branch voltage
    #3 21682675
    Ryan Mco
  • #4 21682676
    Ryan Mco
  • #5 21682677
    Max Maxfield
  • #6 21682678
    Max Maxfield
  • #7 21682679
    Ryan Mco
  • #8 21682680
    David Ashton
  • #9 21682681
    Elizabeth Simon
  • #10 21682682
    Ryan Mco
  • Calls out lack of diagram and source reference
    #11 21682683
    David Ashton
The discussion centers on understanding how a dependent voltage source physically senses and responds to a controlling voltage in a circuit. The main confusion lies in how the dependent source "knows" the voltage at a specific branch to which it is related. Clarifications emphasize that dependent sources are not physical devices like batteries but are theoretical models used in circuit analysis to represent relationships between voltages and currents. They do not possess awareness or sensing capabilities; instead, their behavior is defined by circuit laws such as Ohm's law and theorems by Thévenin and Norton. Dependent sources serve as conceptual tools to simplify the modeling of components like transistors, and their controlling voltages are parameters within these models rather than signals physically transmitted to the source. The discussion advises studying fundamental electronics principles and circuit theorems to grasp these concepts fully.
