Analog load cell amplifier IC for weighing machine with logarithmic output?
264 6
  • #1 21684017
    Graham Rounce
  • #2 21684018
    Giovanni Di Maria
  • #3 21684019
    Graham Rounce
  • Clarifying load cell type and analog log amplifier approach
    #4 21684020
    Richard Gabric
  • TI XTR106 for bridge drive and 4-20mA output
    #5 21684021
    Aubrey Kagan
  • Suggesting a simple analog load-cell meter circuit
    #6 21684022
    Graham Rounce
  • Need gain of at least 1000 for load cell output
    #7 21684023
    Richard Gabric
The discussion focuses on designing an analog weighing machine with a non-digital, analog meter output, ideally with a logarithmic response. The user seeks an integrated circuit that accepts load cell inputs and provides an analog output suitable for driving an analog meter. The HX711, a popular load cell amplifier, was considered but dismissed due to its lack of analog output. The load cells in question are strain gauge types salvaged from digital kitchen scales, with a weighing range up to approximately 500 grams. The output signal from these load cells is low-level (1-5 mV/V), requiring high gain amplification (around 1000x) to drive an analog meter. Suggestions include using precision analog front-end ICs like the Texas Instruments XTR106, which provides a 4-20 mA analog output convertible to voltage, though it is linear rather than logarithmic. Implementing logarithmic output may involve additional analog circuitry such as log amplifiers using dual op amps or diode-based nonlinear elements. Stability concerns such as zero offset, drift, and the need for a stable excitation voltage for the load cell are highlighted. The use of microcontrollers with DACs to generate logarithmic outputs is mentioned as an alternative, but the user prefers a purely analog solution with minimal components.
