Low-Power 3.3V 50mA Isolated Capacitively-Coupled Supply Without Transformer?
360 6
  • Capacitively coupled isolated supply driver options
    #1 21685161
    mixtwitch
  • #2 21685162
    Aubrey Kagan
  • #3 21685163
    PeterTraneus Anderson
  • Clarifying isolation needs for low-EMI supply options
    #4 21685164
    mixtwitch
  • #5 21685165
  • Capacitive isolation needs magnetics for power transfer
    #6 21685166
    Aubrey Kagan
  • #7 21685167
    Aubrey Kagan
The discussion focuses on designing a low-power isolated 3.3V supply delivering up to 50mA without using transformers to minimize EMI and ground loop issues. The original approach considered a capacitively coupled circuit with a bridge rectifier inspired by Maxim's AN4553 application note, but the MAX256 driver chip was deemed oversized for the low power requirement. The isolation target is around 100V+, primarily to prevent ground loops and protect sensitive loads such as a GPS antenna LNA and digital I/O bank. Alternatives suggested include traditional low-frequency (50/60 Hz) transformers known for low noise, small linear power supplies with transformers and regulators, and the "flying capacitor" isolation technique used historically for analog input isolation. Capacitive isolation for power transfer is uncommon due to voltage drop and capacitor size constraints, though data transfer via capacitors is established (e.g., TI's AMC3306M25). A closer alternative to the MAX256 is TI's SN6501, a transformer-coupled driver with smaller size and power closer to the requirements, though still transformer-based. The challenge remains to find a driver capable of differentially driving a square wave below 2 MHz with sufficient source/sink current and complementary outputs for a capacitively coupled isolated power supply.
