How to Make a Glove Alarm That Activates When Fingers Touch Palm for Hand Cramp Detection
300 11
How can I make a glove that sounds an alarm when my fingers curl down and touch my palm for hand cramp detection?
You can make the glove alarm with thin touch contacts or flex sensors on the fingers/palm, then wire them to a small battery-powered buzzer circuit. One simple approach is to put metal contacts on the finger tips and a plate on the palm so that when the fingers touch the palm they close a circuit and trigger the alarm [#21685529] A better wearable option is to glue flexforce sensors to the palm and run the wires to a unit on a belt, using a battery, piezo buzzer, and a few op amps for the conditioning electronics [#21685536] Thin copper metal grill was also suggested as a flexible alternative to rigid metal pads [#21685532] Microswitches and buttons were not recommended because they need too much force to activate [#21685532]
  • Suggesting a palm pressure switch for glove alarm
    #1 21685528
    Big tea
  • #2 21685529
    Giovanni Di Maria
  • #3 21685530
    Big tea
  • #4 21685531
    Big tea
  • #5 21685532
    Giovanni Di Maria
  • #6 21685534
    Big tea
  • #7 21685533
    Big tea
  • #8 21685535
    Giovanni Di Maria
  • Flexforce sensors on palm with belt-mounted alarm
    #9 21685536
    Richard Gabric
  • #10 21685537
    Big tea
  • #11 21685538
    Big tea
  • #12 21685539
    Alexanderlewis
The discussion focuses on designing a glove-based alarm system to detect hand cramps by triggering an alert when fingers touch the palm. Proposed solutions include integrating metal contacts or copper mesh on fingertips and palm to close an electrical circuit upon contact, activating an alarm. Capacitive sensors are mentioned as a more professional but complex alternative. Small mechanical switches or buttons are considered, but their required activation force may be unsuitable given the strong cramps. Flexiforce sensors are suggested as a practical option; these force-sensitive resistors can be attached to the palm, requiring minimal wiring and providing better usability during normal hand movements. The system would involve conditioning electronics such as op amps, a battery, and a piezo buzzer, potentially housed on a belt. MEMS components are also referenced as possible sensor elements. The cramping involves finger joints locking in a strong grip, which influences sensor choice and calibration. The discussion includes considerations for sensor placement, wiring, and alarm activation mechanisms.
TL;DR: Easiest build: fingertip pads touching a palm plate close a circuit; FlexiForce needs only 1 wire pair. “A battery, piezo buzzer, and a few op amps would do it.” [Elektroda, Anonymous, post #21685536]
Why it matters: This helps people who ask “how do I make a glove alarm for cramps?” with simple, low‑force parts and wiring.
What’s the simplest way to detect fingers touching the palm?
Sew or adhere metal pads on fingertips and a metal plate on the palm, then wire them to close a circuit when they touch. This contact closure drives a buzzer or logic input. It needs no force calibration and works with normal gloves. Add insulation around edges to prevent accidental shorts. This approach is inexpensive and fast to prototype with craft copper tape or metalized fabric. [Elektroda, Anonymous, post #21685529]
Are mechanical switches a good idea for cramp detection?
Use them only if grip force is strong during cramps. Mechanical switches need considerable force, which can miss gentle closures or fatigue the user. Touch contacts or force sensors reduce activation effort and bulk in the palm. As one expert noted, “touch contacts are the best solution.” For severe, locking cramps, a low‑force switch can still work if positioned centrally. [Elektroda, Anonymous, post #21685532]
How would I wire a basic battery and alarm to the glove?
Create a simple series circuit: battery positive → alarm/buzzer → glove contact pair → battery negative. When fingers touch the palm, the circuit closes and the buzzer sounds. Keep wire runs short, and strain‑relieve at the glove cuff. Use a small enclosure on a belt or wrist for battery and buzzer. [Elektroda, Anonymous, post #21685534]
Can I put a single device on the palm that triggers when pressed?
Yes. You can mount a pressure‑actuated device on the palm so finger pressure activates it, similar to a slim doorbell concept. This reduces fingertip wiring but still requires low activation force. Place it where the average finger cluster lands during a cramp. [Elektroda, Anonymous, post #21685531]
What is a FlexiForce sensor, and why use it here?
FlexiForce is a thin force‑sensing resistor that outputs a resistance change with pressure. Glued to the palm, it detects finger pressure without multiple fingertip wires. It needs a simple conditioning circuit but only one pair of wires to the belt unit. It tolerates normal hand motion after a quick tare. [Elektroda, Anonymous, post #21685536]
Do I need complex electronics, or will a buzzer suffice?
For basic alerts, a battery and piezo buzzer work. For sensitivity or threshold control, add op‑amps to condition the sensor signal. As one expert said, “A battery, piezo buzzer, and a few op amps would do it.” Keep the circuit light and place it off‑glove. [Elektroda, Anonymous, post #21685536]
How do I build flexible, durable contacts into a glove?
Use thin copper mesh or grill as electrodes for the palm and fingertips. They bend with the fabric and reduce bulk. Stitch or adhesive‑bond them, then cover edges with fabric tape. Route conductors along seams to minimize snagging and improve comfort. [Elektroda, Anonymous, post #21685532]
Will normal hand movements cause false alarms?
With touch contacts, accidental brushing can trigger alarms. Using a force sensor and a calibrated threshold helps. Set a tare so normal flexing sits below the trip point, and cramp force triggers it. Place the sensor where fingers press during a lock. [Elektroda, Anonymous, post #21685536]
What if the cramp locks the fingers tightly?
This scenario suits both touch contacts and force sensors. Locked fingers ensure reliable contact or high pressure. For maximum assurance, use a palm force sensor plus a backup contact plate. The user confirmed that fingers lock during cramps. [Elektroda, Anonymous, post #21685537]
Could MEMS sensors help?
Yes. Small MEMS pressure or touch components can sense compression with minimal bulk. Integrate them in the palm area and feed their output to a threshold circuit or microcontroller. This matches the thread’s principle‑level scheme suggestion for compact sensing. [Elektroda, Anonymous, post #21685535]
Is there a quick 3‑step way to prototype this?
  1. Add fingertip pads and a palm plate (or a palm force sensor).
  2. Wire battery → alarm → sensor path, with strain relief.
  3. Test, adjust sensitivity or plate area, and secure wiring. [Elektroda, Anonymous, post #21685535]
Any edge cases where switches fail?
Yes. High‑activation‑force microswitches may not trigger if the hand closes gently or inconsistently. They can also add uncomfortable pressure points. Prefer touch contacts or low‑force sensors to reduce strain and improve reliability during variable cramps. [Elektroda, Anonymous, post #21685532]
What parts count should I expect for a minimal build?
Typical minimal build uses three core parts: a battery, a piezo buzzer, and a sensor or contact pair. Add two to four small passives for conditioning if using a force sensor. Keep electronics on a belt to reduce glove weight. [Elektroda, Anonymous, post #21685536]
Can someone build this for me?
The thread includes a request for a builder. If you need help, share your location and requirements to engage a local maker or forum member. Provide glove size, sensor choice, and power preference to speed quotes. [Elektroda, Anonymous, post #21685538]
