You're viewing a topic that has been removed.
[BL602] How to flash Magic Home over WiFi without soldering
frankvictor0111 81 0
  • #1 21706484
    frankvictor0111
    >>21056057 It seems like you're attempting to flash the firmware to a BL602 device over-the-air, which is a great way to update without needing to physically modify the hardware. This process is made easier by using an HTTP server to serve the firmware file, allowing you to update the device wirelessly. Just ensure that you have correctly set up the server and connected to the device's access point, as the flashing can only proceed once the device is properly connected to your network. Keep in mind, though, that for any issues during the process, it’s essential to check if the firmware version is compatible with the device.
    Wydzielono z tematu: [BL602] How to flash Magic Home over WiFi without soldering
    przez p.kaczmarek2 dnia 01 Paź 2025 12:30
    Pursuant to Art. 20 of the Digital Services Act (DSA), you can make an appeal to the internet platform provider bok@elektroda.pl or Contact form
