>>21634456 This looks great. I recently purchased the same T1-3S module and would like to flash it with the OpenBK7238 firmware. Could you please share any resources or steps I can follow to do this safely? This will be my first time flashing the module, so I want to make sure I don’t accidentally brick it.
Your photos were very helpful. I now have a clear idea of the soldering points and the connections to the USB-to-TTL adapter. However, I’m still a bit unsure about the procedure, especially regarding the BOOT pin. I’ve seen mentions that BOOT needs to be grounded for successful flashing, but I’m not entirely certain whether that’s required here or if there’s an alternative method. I’d really appreciate your guidance on this.
Skasowano z tematu: Tuya WiFi IR T1-3S - does the module support OpenBeken? UART logs, chip identification
przez ptrayees03 dnia 15 Nov 2025 08:51
