[Solved] VW MFD 1 Navigation Code Retrieval for Passat B5.5 (VWZ1Z7D4080249)
RYM88 1056 4
  • CH341A dump shows address error on 1-byte 3-bit read
    #1 21838527
    RYM88
    Hi!
    I need some help figuring out the code for a VW MFD 1 Navigation unit from a Passat B5.5.
    Serial VWZ1Z7D4080249
    Two dump reads attached; don't know why the 1-byte 3-bit says address error, the 2-byte one doesn't show this.
    @ElektrodaBot
    AI: Could you please upload or link the actual dump files you mentioned? Without them, it's difficult to help retrieve the code.
    They are in the attachment.
    AI: What programmer or tool did you use to read the dumps, and which chip did you read from? This info can help figure out the address error you're seeing.
    CH341A
    • dump2byte.bin (2 KB) You must be logged in to download this attachment.
    • dump1byte3bit1.bin (2 KB) You must be logged in to download this attachment.
  • 2-byte EEPROM read needed for 24C32/64 PIN decode
    #2 21838539
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    RYM88 wrote:
    Hi!
    I need some help figuring out the code for a VW MFD 1 Navigation unit from a passat b5.5.
    Two dump reads in attach, don't know why the 1Byte 3 Bit says adress error...
    Initial assessment of available information
    - Unit: VW MFD 1 (Passat B5.5), serial VWZ1Z7D4080249.
    - Tools: CH341A.
    - Symptom: “1‑Byte 3‑Bit address error”; “2‑Byte” read completes.
    - Attachments exist in the forum thread, but I cannot access them from this interface. I’ll tell you exactly what to post so I can decode the code for you.
    Direct answer to the question
    - Your MFD1’s anti‑theft PIN is stored in an I²C EEPROM inside the FIS (navigation) module. Typical device is 24C32 (sometimes 24C64), i.e., 16‑bit (two‑byte) addressing.
    - The “1‑Byte 3‑Bit” mode is for 24C01…24C16 devices (where the top address bits live in the control byte). On a 24C32/64 this mode will NACK and many programmer GUIs report it as an “address error.” This is expected and not a fault with your board.
    - Use the dump you read in “2‑Byte” mode. That is the correct addressing for 24C32/64 and is the one we can decode.
    Detailed problem analysis
    1. Why the CH341A shows “1‑Byte 3‑Bit address error”
    - 24C01…24C16: internal address = 1 data byte; the upper 3 address bits (A2..A0) are mapped into the device address (that’s the “3‑Bit” in your GUI).
    - 24C32 and larger: internal address = 2 data bytes (high + low). If you try the 1‑Byte/3‑Bit transaction against a 24C32, the device won’t ACK the addressing phase → “address error.”
    - Conclusion: your successful “2‑Byte” read strongly indicates a 24C32/24C64. Discard the 1‑Byte read.
    2. What chip and where
    - Located on the FIS board under the metal shield. Typical markings: AT24C32, M24C32, BR24C32, 24C32WP, etc. Occasionally 24C64.
    - Capacity check: file size should be 4096 bytes for 24C32, 8192 bytes for 24C64.
    3. Reading reliability with CH341A
    - Voltage: Many CH341A “mini” programmers drive I²C at 5 V unless modified. These EEPROMs are 3.3 V. Use a 3.3 V‑fixed or level‑shifted setup. If you must keep the mini board, do the common 3.3 V fix or use a proper programmer (TL866II/T48/T56, XGecu) to avoid marginal reads.
    - In‑circuit vs off‑board: In‑circuit reads often suffer from bus contention (pull‑ups or the main MCU holding SDA/SCL). If the dump looks all FF/00 or is unstable between reads, desolder the chip or isolate VCC/lines. Tie WP (pin 7) low during read/write.
    - Validation: Read the EEPROM 2–3 times and byte‑compare; identical dumps confirm signal integrity.
    4. Where the code lives and how we’ll extract it
    - For Blaupunkt VWZ1Z7 MFD1, the 4‑digit code is in the FIS EEPROM (not calculated from the “VWZ…” serial alone).
    - The storage format differs slightly across firmware variants. Common patterns are:
    - BCD or ASCII digits stored plainly at a fixed offset, sometimes duplicated.
    - Mirrored copy and/or a simple checksum near the end of the sector.
    - With your dump I will locate the correct block, verify mirrors/checksum, and give you the exact 4‑digit PIN.
    5. Misconceptions to clear up (correcting typical forum noise)
    - 93Cxx (Microwire) chips: not used for the MFD1 code in the VWZ1Z7 Blaupunkt FIS module; the target here is I²C 24Cxx.
    - Serial‑only or “sum of digits” methods: do not work for these units. Without the EEPROM content, the code cannot be derived reliably.
    Current information and trends
    - CH341A clones still commonly ship with the 5 V I/O issue; many technicians have moved to TL866II/T48/T56 for robustness, or they permanently 3.3 V‑mod the CH341A and use NeoProgrammer/AsProgrammer for 24xx I²C devices.
    - For stubborn in‑circuit reads, powering the FIS board in the unit while isolating the EEPROM’s pull‑ups sometimes helps, but desoldering remains the most dependable.
    Supporting explanations and details
    - Pinout (24C32 SOIC‑8): 1=A0, 2=A1, 3=A2, 4=GND, 5=SDA, 6=SCL, 7=WP, 8=VCC.
    - Programmer hookup basics: VCC=3.3 V, GND, SDA↔SDA, SCL↔SCL, WP→GND. Keep wires short, use proper pull‑ups (most programmers provide them).
    - Recommended I²C clock ≤100 kHz for stability with long leads/SOIC clip.
    Practical guidelines (do this now so I can decode your code)
    Please post the following from your successful “2‑Byte” dump:
    - Exact file size in bytes.
    - Chip marking as printed on the package (photo or text).
    - Hex snippets (copy/paste) from these regions:
    - 0x000–0x03F (first 64 bytes)
    - 0x1F0–0x230 (64+ bytes around 0x200)
    - 0x3E0–0x420 (if your device is 24C32) or the last 64 bytes of the device if it’s larger
    Example format (addresses on the left are fine):
    00: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
    10: …
    1F0: …
    200: …
    3E0: …
    With those, I’ll read the structure and return the 4‑digit PIN. If you prefer, you can also attach the full dump again in the thread; I’ll pick it up there.
    Common pitfalls and how to avoid them
    - All FF/00 or random data: poor clip contact or wrong voltage. Clean the pins, shorten leads, ensure 3.3 V, try off‑board read.
    - Size mismatch: a “24C64” selected against a 24C32 can give a file full of repeats. Make sure the device selection matches the chip, or use “Read ID/auto” if your software supports it (many 24Cxx don’t have JEDEC IDs—manual selection is normal).
    - One read differs from the next: bus contention; remove the chip or lift VCC and feed from the programmer.
    Ethical and legal aspects
    - Radio codes are an anti‑theft measure. Proceed only if you own the unit. Dealers can also retrieve the PIN with proof of ownership via factory systems.
    Suggestions for further research
    - If you end up doing more of these, consider a TL866II/T48/T56 and a good SOIC8 clip; success rate and repeatability are higher.
    - Keep a verified “original.bin” backup before any edits.
    Brief summary
    - Your “2‑Byte” dump is the correct one; the “1‑Byte 3‑Bit address error” is expected for a 24C32/64.
    - Post the specified hex ranges (or the full 4 KB/8 KB dump). I’ll extract and verify the 4‑digit code for VWZ1Z7D4080249.
    Questions for the user
    - What is the exact EEPROM marking (e.g., AT24C32, M24C64)?
    - What is the byte size of your successful “2‑Byte” dump?
    - Please paste the hex from 0x000–0x03F, 0x1F0–0x230, and 0x3E0–0x420 of that dump. With that, I can give you the code.
  • #3 21838727
    rutra111
    Help: 97
    Rate: 161
    ....0184....
  • #4 21839798
    RYM88
    Worked. Thanks a lot!
  • #5 21840053
    damiancz
    Moderator of Car Radios
    Help: 475
    Rate: 1409
    Resolved = closed
