PicoClaw - ultra-light AI assistant running in < 10 MB RAM
p.kaczmarek2 1677 3
  • PicoClaw is an open-source Go AI assistant that uses external LLM APIs and ships as a single standalone binary with no external dependencies.
  • It was rebuilt with auto-bootstrapping, where the AI agent generated most base code during refactoring under human supervision.
  • It uses less than 10 MB of RAM and boots in less than 1 second on a 0.6 GHz processor.
  • The architecture supports RISC-V, ARM64, and x86, and it can act as a console assistant, CLI tool, chat-bot gateway, or cron scheduler.
  • Its main limitation is reliance on external LLM APIs for model access, messaging, and tools.
  • Screenshot of the PicoClaw page with logo and the headline “Ultra-Efficient AI Assistant in Go”
    PicoClaw is a new open-source AI assistant written in Go that runs using external LLMs (language models) via an API and uses less than 10 MB of RAM. The project was completely rebuilt with inspiration from nanobot and OpenClaw, using so-called auto-bootstrapping, where the AI agent itself generated most of the base code during refactoring with human supervision. As a result, PicoClaw boots in less than 1 second, even on a weak 0.6 GHz processor. The architecture supports three major ISAs (RISC-V, ARM64 and x86), facilitating implementations on devices ranging from low-cost boards to standard PCs or servers. The whole thing compiles to a single standalone binary file, with no external dependencies. This allows the project to run on up to $10 RISC-V hardware at a fraction of the cost of typical AI solutions. PicoClaw integrates with a variety of LLM services (including OpenRouter, Anthropic, OpenAI and others), allowing flexible choice of model backend. Users can use PicoClaw as an assistant in interactive console mode, but also via a single-query CLI. The system allows integration with instant messengers such as Telegram, Discord or DingTalk, acting as a chat-bot gateway. The project also supports scheduled tasks (cron), which enables reminders and automation. With its low memory requirements and fast start-up speed, PicoClaw targets IoT devices, home control centre or AI experiments on a minimal platform.
    Comparison:
    OpenClaw NanoBot PicoClaw
    Language TypeScript Python Go
    RAM >1 GB >100 MB < 10 MB
    Startup (core 0.8 GHz) >500 s >30 s < 1 s
    Cost Mac Mini $599 Most Linux SBCs ~$50 Any Linux board (even from 10$)
    Source:
    https://github.com/sipeed/picoclaw
    Do you see a use for such a lightweight agent implementation? It's certainly a big step forward relative to Mac Mini devices, although it stops being so impressive when you remember that the whole thing runs on an external API from LLM or thereabouts from messaging, tools, etc. There is certainly some upside in terms of security though, the cheaper the hardware, the less the cost of isolating the agent from our main computer....
    p.kaczmarek2 wrote 14827 posts with rating 13014, helped 659 times. Been with us since 2014 year.
  • #2 21851048
    ken-wawa
    Rate: 152
    Why "Any Linux CD (even from $10)"? Linux is not free? :P
  • #3 21851050
    Rate: 13014
    Board, in the sense of any microcomputer, board. I did not choose the price, it is an estimate from the authors of the project:
    Comparison table of OpenClaw, NanoBot and PicoClaw: language, RAM, startup time, cost
    The actual prices of devices capable of running PicoClaw are subject to change.
  • #4 21851068
    ken-wawa
    Rate: 152
    My own intelligence must have fizzled slightly, because it understood "any disc" as a dvd. :P And I wondered why I necessarily needed to buy a dvd with a Linux installation. :P
TL;DR: PicoClaw is a Go-based AI agent that uses "under 10 MB RAM" and boots in <1 second on 0.6 GHz hardware. It talks to external LLMs via API and compiles to a single binary for RISC‑V/ARM64/x86. [Elektroda, p.kaczmarek2, post #21839127]
Why it matters: It brings assistant-class AI to $10 Linux boards for IoT, labs, and secure, isolated deployments.
What is PicoClaw in simple terms?
PicoClaw is a lightweight AI assistant written in Go. It calls external large language models through an API and runs as a single standalone binary with no extra dependencies. It aims at tiny Linux systems yet scales to PCs and servers. [Elektroda, p.kaczmarek2, post #21839127]
How fast does PicoClaw start and on what CPU?
It boots in under one second on a weak 0.6 GHz processor. This speed helps short‑lived tasks and low-power setups. The design favors quick startup and small memory use, which benefits cron jobs and on-demand chat actions. "Boots in less than 1 second." [Elektroda, p.kaczmarek2, post #21839127]
Which hardware architectures does PicoClaw support?
The architecture supports three major ISAs: RISC‑V, ARM64, and x86. That means it runs on cheap RISC‑V boards, common ARM SBCs, laptops, desktops, and servers. A single binary per target keeps deployment simple across fleets. [Elektroda, p.kaczmarek2, post #21839127]
Does PicoClaw run models locally or use the cloud?
It uses external LLM services via API. You choose a provider such as OpenRouter, Anthropic, or OpenAI. This keeps local RAM and CPU use tiny, but requires network access and valid API credentials for responses. [Elektroda, p.kaczmarek2, post #21839127]
What can I actually do with PicoClaw on a $10 board?
Use it as an interactive console assistant, a single‑query CLI tool, or a chat-bot gateway for Telegram, Discord, or DingTalk. You can also schedule reminders or automations through cron, ideal for IoT hubs and labs. [Elektroda, p.kaczmarek2, post #21839127]
Is it secure enough to isolate from my main PC?
Yes, its low hardware requirements reduce isolation cost. You can dedicate a cheap micro‑server to run the agent, limiting lateral risk. Network only the needed APIs and messengers. This is a practical security win for many users. [Elektroda, p.kaczmarek2, post #21839127]
How does PicoClaw compare to OpenClaw and NanoBot?
According to the comparison, OpenClaw uses TypeScript and >1 GB RAM, NanoBot uses Python and >100 MB RAM, while PicoClaw uses Go and <10 MB RAM. Startup time improves to <1 s, slashing latency and power. [Elektroda, p.kaczmarek2, post #21839127]
What is “auto‑bootstrapping” in this project?
Auto‑bootstrapping means the AI agent helped generate much of the base code during refactoring under human supervision. The team rebuilt with lessons from nanobot and OpenClaw to reach fast startup and tiny memory use. [Elektroda, p.kaczmarek2, post #21839127]
What’s the CLI experience like?
You can run PicoClaw in an interactive console session or send a single query from the shell. This suits scripts, CI tasks, and quick lookups. The simple binary design means zero virtualenvs, runtimes, or containers required. [Elektroda, p.kaczmarek2, post #21839127]
How do I hook it to messengers?
It integrates as a chat-bot gateway with Telegram, Discord, or DingTalk. Configure your chosen backend API keys and bot tokens, then route messages to the agent. Expect low idle use and quick cold starts for replies. [Elektroda, p.kaczmarek2, post #21839127]
Can I schedule jobs, reminders, or automations?
Yes. PicoClaw supports scheduled tasks via cron. You can run prompts or workflows on a timetable, such as daily summaries or device checks. Fast startup helps keep schedules punctual even on minimal CPUs. [Elektroda, p.kaczmarek2, post #21839127]
What’s an LLM, and which ones work here?
An LLM is a large language model that generates text. PicoClaw connects to LLMs provided by services like OpenRouter, Anthropic, and OpenAI through their APIs. You pick the backend for cost, speed, or capability. [Elektroda, p.kaczmarek2, post #21839127]
What is cron and why is it mentioned?
Cron is a Unix scheduler that runs commands at specified times. PicoClaw supports cron-triggered tasks, enabling unattended reminders and automations. This pairs well with its sub‑second starts and low memory impact. [Elektroda, p.kaczmarek2, post #21839127]
Are there edge cases where PicoClaw won’t respond?
Yes. If the external LLM API is offline, rate‑limited, or your key is invalid, responses will fail. Network isolation that blocks those services will also stop replies. Local compute remains fine but answers depend on the API. [Elektroda, p.kaczmarek2, post #21839127]
How do I install and try PicoClaw quickly?
  1. Download the PicoClaw binary for your ISA (RISC‑V, ARM64, or x86).
  2. Export your chosen LLM provider API key as an environment variable.
  3. Run in interactive mode or send a single CLI query to test replies. [Elektroda, p.kaczmarek2, post #21839127]
Yes. It enables safe isolation on $10 hosts, rapid cron jobs, and resilient IoT assistants. Labs can standardize on tiny binaries across RISC‑V, ARM64, and x86. The external API tradeoff is real but manageable with tokens and quotas. [Elektroda, p.kaczmarek2, post #21839127]
