You're viewing a topic that has been removed.
TuyaSmartlife Temp-Humidity Sensor (BK7238, AU5068XA) Pinout for OpenBK Firmware
leon22heart 147 0
  • #1 21845567
    leon22heart
    Level 4  
    OpenBK7238_SHT4_GXHTV4_w_Battery
    Warn:CFG:CFG_InitAndLoad: Correct config has been loaded with 0 changes count.
    Info:CFG:CFG_SetDefaultLEDCorrectionTable: setting defaults
    Info:NTP:CLOCK driver initialized.
    Error:CMD:no file early.bat err -2
    Info:SENSOR:SHT3x: using pins 24 (SCL) and 17 (SDA)
    Info:SENSOR:SHT: Detecting sensor type...
    Info:SENSOR:DEBUG SHT_DetectSensorType() testing for SHT4x/GXHTV4 serial: 0x89 got ACK
    Info:SENSOR:SHT: 0x89 cmd: SNB=[FFF24305], CRC=[E0,D0]
    Info:SENSOR:SHT: ✓ Detected SHT4X/GXHTV4 (Valid CRC - Serial via 0x89: FFF24305)
    Info:SENSOR:SHT4X sensor detected
    Error:SENSOR:Only supported on SHT3x
    Info:MAIN:Started SHT3X.
    Info:MAIN:Started Battery.
    Info:MAIN:Main_Init_Delay
    Info:GEN:CHANNEL_Set channel 41 has changed to 1 (flags 0)
    Info:MQTT:Channel has changed! Publishing 1 to channel 41
    Info:MAIN:Using SSID [LOLIDAS24TP_IOT]
    Info:MAIN:Using Pass [22leon22heart22]
    Info:MQTT:MQTT_RegisterCallback called for bT TEMP4/ subT TEMP4/+/set
    Info:MQTT:MQTT_RegisterCallback called for bT bekens/ subT bekens/+/set
    Info:MQTT:MQTT_RegisterCallback called for bT cmnd/TEMP4/ subT cmnd/TEMP4/+
    Info:MQTT:MQTT_RegisterCallback called for bT cmnd/bekens/ subT cmnd/bekens/+
    Info:MQTT:MQTT_RegisterCallback called for bT TEMP4/ subT TEMP4/+/get
    Info:MQTT:MQTT_RegisterCallback called for bT homeassistant/ subT homeassistant/+
    Info:CMD:CMD_StartScript: started @startup at the beginning
    Info:CMD:CMD_StartScript: started autoexec.bat at the beginning
    Info:HTTP:TCP server listening
    Info:MAIN:Time 1, idle 534747/s, free 134672, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/24
    Info:GEN:CHANNEL_Set channel 0 has changed to 242 (flags 0)
    Info:MQTT:Channel has changed! Publishing 242 to channel 0
    Info:GEN:CHANNEL_Set channel 1 has changed to 47 (flags 0)
    Info:MQTT:Channel has changed! Publishing 47 to channel 1
    Info:SENSOR:SHT3X_Measure: Temperature:24.2C Humidity:47%
    Info:DRV:DRV_BATTERY : Measure Battery volt en perc
    Info:DRV:DRV_BATTERY : ADC Value low device not on battery
    Info:DRV:DRV_BATTERY : battery voltage : 608.789063 and percentage 0.000000%
    Info:MAIN:Time 2, idle 426738/s, free 134584, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 3, idle 356847/s, free 134584, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 4, idle 395570/s, free 134584, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 5, idle 397831/s, free 134584, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Registered for wifi changes
    Info:MAIN:Connecting to SSID [LOLIDAS24TP_IOT]
    Info:MAIN:Time 6, idle 43437/s, free 127456, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Main_OnWiFiStatusChange - WIFI_STA_DISCONNECTED - 2
    Info:MAIN:Time 7, idle 350345/s, free 128016, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 8, idle 395567/s, free 128016, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 9, idle 392433/s, free 128016, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 10, idle 395139/s, free 128016, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/24
    Info:GEN:dhcp=0 ip=0.0.0.0 gate=0.0.0.0 mask=0.0.0.0 mac=e4:ae:e4:19:1b:ee
    Info:GEN:sta: 0, softap: 0, b/g/n
    Info:MAIN:Time 11, idle 396853/s, free 128016, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/24
    Info:GEN:CHANNEL_Set channel 0 has changed to 241 (flags 0)
    Info:MQTT:Channel has changed! Publishing 241 to channel 0
    Info:GEN:CHANNEL_Set channel 1 has changed to 46 (flags 0)
    Info:MQTT:Channel has changed! Publishing 46 to channel 1
    Info:SENSOR:SHT3X_Measure: Temperature:24.1C Humidity:46%
    Info:DRV:DRV_BATTERY : battery voltage : 1520.507813 and percentage 0.000000%
    Info:MAIN:Time 12, idle 348293/s, free 127784, MQTT 0(0), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 13, idle 362362/s, free 115160, MQTT 0(0), bWifi 1, secondsWithNoPing -1, socks 3/24
    Info:MQTT:mqtt_userName leon22heart
    mqtt_pass ********
    mqtt_clientID TEMP4
    mqtt_host raspi5-home:1883
    Info:MQTT:mqtt_host raspi5-home is being resolved by gethostbyname
    Info:MAIN:Time 14, idle 389555/s, free 121904, MQTT 0(0), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MQTT:mqtt_host raspi5-home resolution SUCCESS
    Info:MAIN:Time 15, idle 343277/s, free 121848, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MQTT:mqtt_subscribed to TEMP4/+/set
    Info:MQTT:mqtt_subscribed to bekens/+/set
    Info:MQTT:mqtt_subscribed to cmnd/TEMP4/+
    Info:MQTT:mqtt_subscribed to cmnd/bekens/+
    Info:MQTT:mqtt_subscribed to TEMP4/+/get
    Info:MQTT:mqtt_subscribed to homeassistant/+
    Info:MAIN:Time 16, idle 382097/s, free 122128, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 17, idle 397027/s, free 113824, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 18, idle 382826/s, free 122128, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 19, idle 386020/s, free 122128, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 20, idle 381650/s, free 121512, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 3/24
    Info:GEN:dhcp=0 ip=192.168.1.144 gate=192.168.1.1 mask=255.255.255.0 mac=e4:ae:e4:19:1b:ee
    Info:GEN:sta:rssi=-61,ssid=LOLIDAS24TP_IOT,bssid=9c:05:d6:ba:e3:ee,channel=11,cipher_type:CCMP
    Info:MAIN:Time 21, idle 378106/s, free 122128, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:GEN:CHANNEL_Set channel 0 has changed to 240 (flags 0)
    Info:MQTT:Channel has changed! Publishing 240 to channel 0
    Info:MQTT:Publishing val 240 to TEMP4/0/get retain=0
    Info:GEN:No change in channel 1 (still set to 46) - ignoring
    Info:SENSOR:SHT3X_Measure: Temperature:24.0C Humidity:46%
    Info:MQTT:MQTT client in mqtt_incoming_publish_cb topic TEMP4/0/get
    Info:MQTT:Publishing val 1548 to TEMP4/voltage/get retain=0
    Info:MQTT:Publishing val 0 to TEMP4/battery/get retain=0
    Info:DRV:DRV_BATTERY : battery voltage : 1548.046875 and percentage 0.000000%
    Info:MQTT:MQTT client in mqtt_incoming_publish_cb topic TEMP4/voltage/get
    Info:MAIN:Time 22, idle 389839/s, free 120584, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    OpenBK7238_SHT3x_getSerial
    Info:SENSOR:SHT : Status : 00 00
    Info:MAIN:Time 1, idle 566448/s, free 129448, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/24
    Info:GEN:CHANNEL_Set channel 0 has changed to -450 (flags 0)
    Info:MQTT:Channel has changed! Publishing -450 to channel 0
    Info:GEN:No change in channel 1 (still set to 0) - ignoring
    Info:SENSOR:SHT3X_Measure: Temperature:-45.0C Humidity:0%
    Info:DRV:DRV_BATTERY : battery voltage : 601.757813 and percentage 0.000000%
    Info:MAIN:Time 2, idle 439911/s, free 129360, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 3, idle 376437/s, free 129360, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 4, idle 411128/s, free 129360, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 5, idle 411691/s, free 129360, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 6, idle 43734/s, free 122240, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 7, idle 344880/s, free 122800, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 8, idle 387321/s, free 122800, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 9, idle 387438/s, free 122800, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 10, idle 387760/s, free 122800, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 11, idle 387700/s, free 122800, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/24
    Info:GEN:No change in channel 0 (still set to -450) - ignoring
    Info:DRV:DRV_BATTERY : battery voltage : 1518.164063 and percentage 0.000000%
    Info:MAIN:Time 12, idle 381524/s, free 114272, MQTT 0(0), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 13, idle 356186/s, free 114272, MQTT 0(0), bWifi 1, secondsWithNoPing -1, socks 2/24
    mqtt_pass ********
    mqtt_clientID TEMP4
    Info:MAIN:Time 14, idle 403314/s, free 116080, MQTT 0(0), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 15, idle 377469/s, free 116624, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 16, idle 373695/s, free 116904, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 17, idle 379831/s, free 106928, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 18, idle 383069/s, free 106928, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 19, idle 383197/s, free 106928, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 20, idle 403129/s, free 116904, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:GEN:sta:rssi=-62,ssid=LOLIDAS24TP_IOT,bssid=9c:05:d6:ba:e3:ee,channel=11,cipher_type:CCMP
    Info:MAIN:Time 21, idle 406594/s, free 116904, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MQTT:Publishing val 1529 to TEMP4/voltage/get retain=0
    Info:DRV:DRV_BATTERY : battery voltage : 1529.882813 and percentage 0.000000%
    Info:MAIN:Time 22, idle 429697/s, free 115360, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MQTT:MQTT client in mqtt_incoming_publish_cb topic TEMP4/battery/get
    Info:MAIN:Time 23, idle 361659/s, free 116904, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 24, idle 401325/s, free 106928, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 25, idle 403186/s, free 116904, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 26, idle 404500/s, free 116904, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 27, idle 406706/s, free 116904, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 28, idle 403457/s, free 116168, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 3/24
    Info:SENSOR:SHT3X Serial: 00000000 (Valid CRC)
    Info:CMD:[WebApp Cmd 'SHT_GetSerial ' Result] OK
    Info:MAIN:Time 29, idle 412598/s, free 116904, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 30, idle 403226/s, free 116904, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 31, idle 417284/s, free 116904, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MQTT:Publishing val 1536 to TEMP4/voltage/get retain=0
    Info:DRV:DRV_BATTERY : battery voltage : 1536.914063 and percentage 0.000000%
    Info:MAIN:Time 32, idle 437209/s, free 113816, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 33, idle 345615/s, free 116904, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 34, idle 381617/s, free 116904, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 35, idle 386753/s, free 116904, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 36, idle 399100/s, free 116904, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 37, idle 400280/s, free 116904, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 38, idle 390086/s, free 116288, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 3/24
    Error:CMD:cmd SHT_SetType NOT found (args 3)
    Info:CMD:[WebApp Cmd 'SHT_SetType 3' Result] Unknown command
    Info:MAIN:Time 39, idle 410569/s, free 116904, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 40, idle 417407/s, free 116904, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 41, idle 413838/s, free 116904, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MQTT:Publishing val 1542 to TEMP4/voltage/get retain=0
    Info:DRV:DRV_BATTERY : battery voltage : 1542.773438 and percentage 0.000000%
    Info:MAIN:Time 42, idle 448350/s, free 115016, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 43, idle 362800/s, free 116816, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 44, idle 388240/s, free 116904, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 45, idle 395808/s, free 116904, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 46, idle 386440/s, free 116904, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Error:CMD:cmd SHT_SetType NOT found (args 4)
    Info:CMD:[WebApp Cmd 'SHT_SetType 4' Result] Unknown command
    Info:MAIN:Time 47, idle 395960/s, free 116288, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 3/24
    Info:MAIN:Time 48, idle 402094/s, free 116904, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 49, idle 411111/s, free 108600, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 50, idle 410086/s, free 116904, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 51, idle 419446/s, free 116904, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Error:CMD:cmd SHT_SetType NOT found (args 5)
    Info:CMD:[WebApp Cmd 'SHT_SetType 5' Result] Unknown command
    Info:MQTT:Publishing val 1604 to TEMP4/voltage/get retain=0
    Info:DRV:DRV_BATTERY : battery voltage : 1604.296875 and percentage 0.000000%
    Info:MAIN:Time 52, idle 433556/s, free 115248, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 53, idle 357872/s, free 116904, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 54, idle 396577/s, free 116904, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    [\code]
    Skasowano z tematu: TuyaSmartlife Temp-Humidity Sensor (BK7238, AU5068XA) Pinout for OpenBK Firmware
    przez leon22heart dnia 22 Feb 2026 11:28
