[Solved] ASUS X550EP / X552E Rev 2.0 – Need full 4MB BIOS dump (W25Q32FV, AMD)
HyperPfc 549 6
  • #1 21893352
    HyperPfc
    I need the full 4 MB BIOS dump for ASUS X550EP / X552E Rev 2.0 (AMD E1-2500) with W25Q32FV chip.
    My original BIOS is corrupted after address 0x001EAFC0 (all FF).
    The chip was read correctly (4,194,304 bytes), but the BIOS region is partially erased.
    If someone has a clean working dump for this motherboard revision, please share it.
    Thank you very much.
  • #2 21893425
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8291
    Please post here Your original, damaged BIOS dump. There may be some data worth saving and it may be used to reconstruct a working BIOS dump for You.
  • #3 21894136
    HyperPfc
    Bonjour,
    Voici mon dump BIOS original et endommagé, comme demandé.
    Dump lu avec CH341A depuis la puce Winbond 25Q64FV.
    Merci d’avance pour votre aide à la reconstruction.
    • evelyne-backup_bios_original.zip (1.73 MB) You must be logged in to download this attachment.
    Rebuilt BIOS dump with transferred DMI and license data
    #4 21894304
    dt1
    Help: 7315
    Rate: 8291
    This BIOS seems complete, it is not empty after 0x001EAFC0 - check ~0x00340000 and after.
    I found another BIOS dump and there was a lot of empty space in it (0xFF), just like in Your dump.
    Nevertheless I created for You a new BIOS dump based on an update file from Asus website. I transferred DMI data (serial, model, UUID and so on) and OS license from Your dump to the new one. It is the same version as the original (303). BIOS settings were not transferred (defaults should be used).
    This may work or not - let me know if You decide to try it.
    • new_E8N0CV030023325.bin (4 MB) You must be logged in to download this attachment.
  • #5 21894510
    HyperPfc
    >>21894304
    Bonjour,
    Je voulais vraiment vous remercier pour l’aide que vous m’avez apportée.
    Le BIOS que vous avez reconstruit fonctionne parfaitement : la machine démarre, Windows se lance sans problème, et tout est à nouveau opérationnel.
    Votre travail a été précieux. Vous avez pris le temps de analyser mon dump, reconstruire un fichier propre, transférer les données DMI… et grâce à vous, un PC qui semblait perdu est reparti comme neuf.
    Franchement, merci pour votre disponibilité, votre compétence et votre patience.
    Je vous suis très reconnaissant pour votre aide.
    Cordialement.
    dt1
    Help: 7315
    Rate: 8291
    I am glad that it works, thank you for feedback :)
  • #7 21894590
    HyperPfc
    Bonjour,
    Le problème est maintenant résolu.
    Le BIOS a été réparé à partir de mon dump original, et après reprogrammation de la puce, l’appareil fonctionne à nouveau correctement.
    Je tiens également à souligner la qualité et la précision de l’aide reçue, qui a été vraiment impeccable.
    Merci encore pour votre support.
Request for a clean full 4 MB BIOS dump for ASUS X550EP / X552E Rev. 2.0 motherboard with AMD E1-2500 and W25Q32FV flash chip. The original BIOS image is corrupted from address 0x001EAFC0 onward, where the data is all FF, although the chip was read successfully at 4,194,304 bytes. A reply asks to upload the damaged original dump so any recoverable data can be used to reconstruct a working BIOS image.
