[Solved] Fiat Punto Evo Delphi F199FL EUR 7355649810 – code from 24C32 dump
mandaram 312 2
  • Request to verify repeated 24C32 reads
    #1 21939438
    mandaram
    Could someone please calculate the original PIN code from the attached EEPROM dump?
    Radio: Fiat Punto Evo
    Manufacturer: Delphi
    Model: F199FL EUR
    Fiat part number: 7355649810
    EEPROM: 24LC32 / 24C32
    Dump size: 4096 bytes
    The EEPROM was read with a Dataman programmer.
    I only need the original 4-digit PIN.
    No CAN OFF, no CODE OFF and no EEPROM modification.
    Thank you very much.
    AI: Could you please attach the actual 4096-byte EEPROM dump file, or confirm that it is attached and readable by other users?
    Yes
    AI: Did you read the 24C32 more than once and verify that the dumps are identical, to rule out a bad read?
    Yes
    • autoradio.bin (4 KB) You must be logged in to download this attachment.
    rybeh
    Help: 134
    Rate: 284
    It should fit 1152
  • #3 21947785
    mandaram
    Great! It works – thank you very much!
