Delphi 250 FL car stereo dead after technician resoldered two ICs
gensa1453 510 3
  • Need fuse, 12 V, and current-draw checks
    #1 21905942
    gensa1453
    I have a Delphi 250 FL car stereo, and an electronics technician ruined it. It used to turn on, but now it's completely unresponsive. He resoldered the two integrated circuits marked in the photos, and now the device is gone; it won't turn on. Can you help me?
    Can you show the photos and tell us exactly which two ICs were resoldered/replaced (part numbers or board labels), and whether the technician only reheated the solder or actually changed the chips?
    He removed the integrated circuit and put it back in; I don't know if he mixed things up or what, but it was working until then. I had the device turned on because of the noise.
    After this happened, what checks have you done on the radio—fuse, 12 V power at the connector, any current draw, heating, smell, or any sign of life at all (display/backlight/click)?
    The device used to turn on, but now it doesn't turn on at all.
    • Delphi 250 FL car stereo dead after technician resoldered two ICs WhatsApp Image 2026-05-18 at 18.47.08.jpeg (324.05 KB) You must be logged in to download this attachment.
    • Delphi 250 FL car stereo dead after technician resoldered two ICs WhatsApp Image 2026-05-18 at 18.47.08 (1).jpeg (282.16 KB) You must be logged in to download this attachment.
    • Delphi 250 FL car stereo dead after technician resoldered two ICs WhatsApp Image 2026-05-18 at 18.47.09.jpeg (183.19 KB) You must be logged in to download this attachment.
    • Delphi 250 FL car stereo dead after technician resoldered two ICs WhatsApp Image 2026-05-18 at 18.47.09 (1).jpeg (402.8 KB) You must be logged in to download this attachment.
    • Delphi 250 FL car stereo dead after technician resoldered two ICs WhatsApp Image 2026-05-18 at 18.47.09 (2).jpeg (380.95 KB) You must be logged in to download this attachment.
  • #2 21905966
    DiZMar
    Help: 2894
    Rate: 6675
    gensa1453 wrote:
    Removed the chip and put it back in; don't know if he messed something up or what, but by then it was working.
    Then why did you have the technician do anything? Did you give it to him to damage?
    gensa1453 wrote:
    I had the unit switched on because of the noise.
    What is the issue?
  • #3 21905974
    viayner
    Help: 1563
    Rate: 2055
    The pictures are of poor quality, initially check that e.g. the orientation of the circuits is correct, further that there are no short circuits between the leads. Did the device stop working immediately after the intervention of this technician or after time?
    Exactly what is the issue:
    gensa1453 wrote:
    I had the device switched on due to noise.
    Greetings.
  • #4 21906581
    robert nawrot
    Help: 31
    Rate: 110
    Did this "technician" solder with a transformer soldering iron or is he a plumber by trade and soldered with a gas torch to Cu pipes because he messed up a lot of solder ?
    Compare to the ICs above what the soldered circuit :) should look like
