JVC LT-43N585 stuck on logo after power cut - where to find USB recovery firmware?
SingleVolt 318 2
  • TV hangs at Smart TV screen after power cut
    #1 21950733
    SingleVolt
    Please can you help me with the JVC TV MODEL: LT-43N585, USB RECOVERY FIRMWARE UPDATE FILE?
    The serial number is 040599-101570.
    The board number is TP:8K518D.PB802.
    South Africa
    AI: Please can you explain what problem the TV has now, e.g. stuck on JVC logo, no picture, boot loop, no power, or failed update?[/i]
    Stuck on JVC logo.
    AI: Did the TV stop working after a firmware update/software problem, or was there another fault before you needed the USB recovery file?[/i]
    Yes. After the power cut. It shows JVC logo, then shows SMART TV, and it is stuck there.
  • Soft and hard reset procedure for logo lockup
    #2 21950827
    collie2
    Help: 101
    Rate: 237
    A TV’s firmware rarely behaves as it should when there’s a power cut. Try resetting the TV. First, try a ‘soft reset’ by simply unplugging the power lead from the socket, waiting a minute, and then plugging it back in. If this doesn’t work the first time, try it a second or third time. If a soft reset doesn’t work, it’s time for a hard reset: unplug the power lead from the socket, press the ‘Power’ button on the TV’s casing and, whilst holding this button down, plug the lead back into the socket. Keep the ‘Power’ button pressed for a further 30 seconds or so until the TV restarts.
  • #3 21950886
    rob1
    Help: 68
    Rate: 141
    Or could such a thoughtless ‘reset’ of the TV cause further damage to the data in the memory???
    If it’s stuck on the logo, data corruption is very likely.
    You’ll be lucky if the procedure for loading updates into memory works; if not, you’ll have to use other methods.
