Toshiba 55UA2068DGL - stuck on logo loop, where to get USB recovery firmware?
PiDramSector 321 2
  • Logo loop started after failed software update
    #1 21947694
    PiDramSector
    Hello, I need the USB recovery firmware for Toshiba TV.
    Model: 55UA2068DGL
    VPA / Article No: 10136217
    SN: 8769732 200459
    The TV is stuck on the Toshiba logo loop. Thanks!
    AI: Do you know the current firmware/software version, or can you see it on any sticker/service menu before it reboots?
    Model: 55UA2068DGL
    VPA: 10136217
    Serial Number: 8769732 200459
    AI: Have you already tried a full power reset or factory reset procedure, and did the TV start looping after an update or suddenly by itself?
    Yes, the issue started immediately after performing a software update; the TV remained stuck at the Toshiba logo and reboots again after a few seconds. I have tried to do a full factory reset by using the Power button combinations as well as a full power cycle reset (unplugging the TV for minutes), but unfortunately, nothing has worked.
  • #2 21947877
    jvegaavero
    tengo un TV Toshiba 40L2863DG MB211S. La imagen está volteada. Necesito un firmware. Ayuda, gracias.
  • #3 21947884
    yokoono51
    Help: 176
    Rate: 321
    jvegaavero wrote:
    tengo un tv tohsiva 40l2863dg mb211s la imagen esta volteada necesito un fieware ayuda gracias
    1. Create a separate post.
    2. You don't need software to flip the image.
    3. It can be flipped via the panel profile.
    4. You need to know the panel code (VES400xxxx-xx-xx). VES400UNDS-2D-N12 ????
    I will only reply to you in your own post.
