Toshiba 32WA2063DG 17MB171 - image upside down after USB firmware flash
Giannidio 99 2
  • Correct firmware needed for VES315WNQL-2D-N52 panel
    #1 21954848
    Giannidio
    I am looking for the correct full USB recovery firmware for the following TV:
    Toshiba 32WA2063DG
    Mainboard: 17MB171
    Panel: VES315WNGL-2D-N52
    Panel code: 28756488
    Product code: 10140199
    Native resolution: 1366x768 HD Ready
    The original problem was “storage space running out”, after which the TV became almost unusable.
    I first flashed an incorrect firmware package, which loaded an FHD 1920x1080 panel profile and caused a badly distorted/split picture.
    Afterwards, I flashed:
    MB171_PT320AT02-2
    upgrade_no_tvcertificate.pkg
    Now the TV boots and the picture geometry/timing is correct, but the entire image is rotated 180 degrees/upside down, so this is obviously not the correct panel configuration for my TV.
    I have now opened the TV and confirmed that the actual LCD panel is:
    VES315WNGL-2D-N52
    Vestel panel code: 28756488
    Could someone please provide the correct full firmware/upgrade_no_tvcertificate.pkg for:
    Toshiba 32WA2063DG + 17MB171 + VES315WNGL-2D-N52
    Preferably, the original Toshiba/Vestel firmware, including the correct panel configuration.
    If a full firmware is not available, the correct panel/PQ configuration file for VES315WNGL-2D-N52 would also be very helpful.
    Thank you very much in advance.
    AI: Could you please provide a clear photo or the full text of the rear TV label and the mainboard sticker, including serial number, barcode numbers, and any Vestel/Toshiba variant codes?
    Yes.
    AI: Can you still access the service menu, and if yes, what software version, panel profile/name, and option bytes/settings are currently shown there?
    No.
    yokoono51
    Help: 176
    Rate: 321
    Panel: VES315WNQL-2D-N52. No.
    The panel is VES315WNGL-2D-N52
  • #3 21955035
    Giannidio
    Thank you, my friend. You are absolutely right — that was my typo.
