I'm looking for a firmware dump for this exact board/panel combination. My original board's SPI flash appears to be corrupted and I can't get a usable read from it, so I'm hoping someone here already has a matching working dump.
Mark: Smart Tech
Model: LE-32D11
Panel P/O: T1706-60K
Chassis/Mainboard: TP.MS3463S.PB801
LCD Panel: LSC320AN10-H (panel label also shows CX316DLEDM)
Sticker/batch code on mainboard: R17061057-0A03612
Backlight rating printed on label: 370 mA, 65 W02, 37%
I've bought a replacement TP.MS3463S.PB801 board and I'm trying to verify/flash the correct firmware onto it using a SOIC8 clip + CH341A programmer before installing it, since the original board's flash can no longer be dumped.
If anyone has a working dump for this exact model, or can confirm whether a firmware file for plain "LSC320AN10" (without the -H suffix) would be safe to try, I'd really appreciate it. Happy to post more photos of the board/label if that helps identify it.
Thanks in advance!
Mark: Smart Tech
Model: LE-32D11
Thanks in advance!
