Seat Ibiza 2005 fuse locations for parking lights and meaning of flashing INSP indicator
wogvorph 179336 12
Where are the fuses for the parking lights on a 2005 Seat Ibiza, and what does the flashing INSP indicator mean?
The fuse box is behind the cover on the left side of the console, visible when the door is open, or on the left side of the steering wheel, and the flashing INSP means the service interval is approaching or overdue. [#3569320] If the inspection is already overdue, an electrician can clear the indicator and set the next service interval. [#3569320] To check a suspect fuse, turn on the parking lights and test both sides of each fuse with a test lamp or ohmmeter; a good fuse should show continuity/power on both sides. [#3582552] [#3587037]
  • #1 3569164
    wogvorph
    Rate: 36
    I recently bought a Seat Ibize 2005.
    Actually, I don't know anything about cars and that's where my problem arises.
    Front right and rear right parking lights (all red) are inoperative. I realize it could be the fault of the fuses.
    Where should I look for them?
    ps. I don't want to have a separate topic, but what does the flashing "INSP" mean? And can it be turned off somehow?
    Thanks for the help in advance.
    Regards
    cardiag
    Level 30  
    Help: 104
    Rate: 565
    the fuses are behind the plug on the left side of the console (you can see it when the door is open) or on the left side of the steering wheel.
    INSP -> informs you that the time of the visit to the service is approaching (oil change, filters, etc.). If you are already behind you, go to the electrician, he will delete the information about the inspection and set the time for the next inspection)
  • #3 3579095
    wogvorph
    Rate: 36
    Anyone have a photo of fuses in ibiz (2005)? Because I think I'm missing some and I don't know what and how.
    ps: how much may it cost to install the power steering?
    Trawik
    Help: 75
    Rate: 442
    here you have a description of the fuses
    • Seat Ibiza 2005 fuse locations for parking lights and meaning of flashing INSP indicator ibiza.jpg (213.69 KB) You must be logged in to download this attachment.
  • #5 3579378
    wogvorph
    Rate: 36
    Thank you. How do you know, for example, which swallow is No. 4? I only have 5 others there 10 :P I apologize for such questions, but I am a soupy layman: \
  • #6 3579852
    Trawik
    Help: 75
    Rate: 442
    here's the rest
    • Seat Ibiza 2005 fuse locations for parking lights and meaning of flashing INSP indicator seta1.jpg (142.83 KB) You must be logged in to download this attachment.
  • #7 3579973
    wogvorph
    Rate: 36
    In the 2005 model, I have fuses on the left side of the steering wheel (as you can see the door opening) in a different layout ...
  • #8 3582552
    viper555
    Help: 582
    Rate: 2161
    Turn on the parking lights and the 12V indicator light check all fuses by checking on both sides of the fuse, on one side you will have no electricity. P
  • #9 3583499
    wogvorph
    Rate: 36
    Already everything chya is ok, but for a shower I would rather know which fuse is from what.
  • #10 3585339
    viper555
    Help: 582
    Rate: 2161
    Since this is the year 2005, I do not understand where the operating manual is, where each fuse is described in detail
  • #11 3587037
    darekb1
    Rate: 33
    as for the fuses, you can also check them with an ohmmeter - set it to the "buzzer" and check, if it squeals it is ok, if not burnt :) Greetings
  • #12 3588346
    wogvorph
    Rate: 36
    Ehhh, do you really think if I had a manual I would ask here? :)
  • #13 16240502
    witek1965
    Rate: 121
    Maybe someone else will provide a description of the fuses with a diagram for Ibiza 2000-2002 Pb.
The discussion revolves around troubleshooting the inoperative front right and rear right parking lights on a 2005 Seat Ibiza, with a focus on checking the fuses. Users suggest that the fuses are located behind the plug on the left side of the console or near the steering wheel. There are requests for a fuse diagram and clarification on identifying specific fuses. Additionally, the "INSP" warning light is explained as an indicator for upcoming service maintenance, which can be reset by an electrician. Various methods for checking fuses, including using an ohmmeter, are also mentioned.
