Instructions for Replacing 2009 Ibiza 1.2 Petrol 6j Front Right Lamp - Screw and Wound Issues
conrada 16110 4
  • #1 16454372
    conrada
    Hello, do you have any instructions on how to replace the 2009 Ibiza 1.2 petrol 6j? after unscrewing the screws - 4 pieces cannot be pulled out through the wounds on the side and top of the lamp. what's more, I have to undress - of course I would like to undress as little as possible?
  • #2 16454958
    tzok
    Help: 3175
    Rate: 6546
    You have to remove the bumper.
  • #3 16455357
    conrada
    I have to take off the whole thing, can I take it from one to the other - generally the right side only want?
  • #4 16455508
    tzok
    Help: 3175
    Rate: 6546
    If you want to exercise and risk damaging the paintwork on the bumper or breaking one of the fasteners, you can unscrew 2/3 - that is the center + fastening to the fender on the side of the lamp you want to remove. You need to remove the bumper from the front belt so that it goes down under the lamp by at least 10 cm. When you do it yourself, you will see if it is enough or not.
    Anyway, what I will write about:
  • #5 16634211
    conrada
    Replaced - a bit bad to do in the parking lot, but managed not to break anything. So I recommend one to work out in order to save money on mechanics. Best regards.
