Is Gaussian Noise the Same as White Gaussian Noise? Explaining the Difference
Oberon 26344 8
  • #1 3821522
    Oberon
    Help: 18
    Rate: 11
    I have a question: is Gaussian noise white Gaussian noise? Could someone briefly explain what the difference is? :?:
    Because I`m already confused :cry:
  • #2 3821796
    Jerzy Węglorz
    Help: 501
    Rate: 451
    Hello!
    In Wikipedia they write:
    http://en.wikipedia.org/wiki/Additive_white_Gaussian_noise
    it is broadband noise or otherwise "white" noise, with constant spectral density (expressed in Watts per Hertz within the band under consideration) i Gaussian amplitude distribution .
    Gaussian noise can come from many natural sources: thermal vibrations of the atomic lattice of the antenna material (called thermal or Johnson-Nyquist noise), the radiance of a black body, and also the Sun.
    Therefore, there may also be "pink" noise (with a "privileged" frequency band) and a Gaussian distribution of amplitudes, as well as "white" noise with a non-Gaussian distribution (e.g. due to the operation of an amplitude limiter or, for example, a logarithm amplifier).
    On this topic, Google gives you over 1.1 million pages in English...
  • #3 3822042
    Oberon
    Help: 18
    Rate: 11
    The first thing I did was to use Google/Wikipedia and the books I have:
    and I`m confused (and I`ve been sitting on it for about 2 hours now and reading it :| either I`m explaining it wrong or I didn`t understand something [I didn`t have a course like Signal Analysis - or similar and I have to learn it myself, so please be understanding])
    because in:
    http://en.wikipedia.org/wiki/Gaussian_noise
    I found something like this:
    "Gaussian noise is sometimes misunderstood to be white Gaussian noise, but this is not the case."
    Moving on
    in http://en.wikipedia.org/wiki/White_noise I found:
    It is often incorrectly assumed that Gaussian noise (ie noise with a Gaussian amplitude distribution — see normal distribution) is necessarily white noise. However, neither property implies the other. Gaussianity refers to the way signal values are distributed, while the term `white` refers to the shape of the power spectral density. White noise has a flat spectrum, similar to that of white ligh, hence the name.
    so should I understand that White Gaussian Noise is White Noise in the appropriate distribution of occurrences (hence the word gaussian)? And that White noise is not the same as Gaussian noise?
    because I don`t know what this ambiguity is (what makes them different)
    Please give me a relatively simple explanation
    Jerzy Węglorz
    Help: 501
    Rate: 451
    Look again at my first and third paragraphs:
    - the term "white" refers only to spectral distribution , does not say anything about the amplitudes, so white noise remains white after passing through, for example, a logarithmic amplifier, but after passing through a selective amplifier there is no white noise anymore, it is "pink" or any other "colored" noise;
    - the term "Gaussian" refers to amplitude distribution noise components, i.e. that some instantaneous amplitude is the most probable, and smaller and larger amplitudes have a probability consistent with the Gaussian distribution, but nothing is said about the spectral distribution, which means that Gaussian noise after passing through a linear selective amplifier remains Gaussian , while passing through a logarithm amplifier or amplitude limiter causes the noise to have a non-Gaussian distribution.
  • #5 3822200
    Oberon
    Help: 18
    Rate: 11
    I read your words carefully 10 times to be sure and understood what you said. Thank you :D
    One more question just to be sure:
    Can you say that:
    "HV is like a special case of HV with a Gaussian amplitude distribution and vice versa with GN with HV spectrum"
  • #6 3823668
    Jerzy Węglorz
    Help: 501
    Rate: 451
    Exactly! It belongs to both classes at the same time.
  • #7 3824245
    maciej747
    Rate: 20
    Oberon6:
    Gaussian noise is one in which the samples are independent random variables with a uniform Gaussian distribution. However, Gaussian white noise is Gaussian noise in which the average value of this common Gaussian distribution is also 0.
    Regards,
    Maciej
  • Questioning whether Gaussian white noise has a normal spectrum
    #8 10036657
    mariuszprus
    I have a question that will finally resolve this question.
    To sum up, white noise is one whose signal spectrum is flat, i.e. the amplitudes of the signals constituting the spectrum are the same and theoretically range from 0 to infinity (in fact, some range). Now, if we take into account Gaussian white noise, the spectrum of such a WGN looks like a normal distribution with frequencies from a previously defined frequency range. That`s right ?
  • #9 10040489
    Elektronik9
    Level 30  
    Help: 21
    Rate: 195
    No, the distribution of instantaneous amplitudes has a Gaussian distribution, in the frequency domain there is a, let`s say, "uniform" distribution.
Gaussian noise and white Gaussian noise are related but distinct concepts. Gaussian noise refers to noise with an amplitude distribution that follows a Gaussian (normal) distribution, while white Gaussian noise (WGN) is a specific type of Gaussian noise characterized by a flat spectral density across frequencies, meaning it has equal power across the frequency spectrum. The term "white" indicates that the noise has a constant spectral density, whereas "Gaussian" pertains to the statistical distribution of the amplitudes. Thus, while all white Gaussian noise is Gaussian noise, not all Gaussian noise is white. The discussion also touches on the implications of passing these noises through various amplifiers, which can alter their characteristics.
