Pulling Speaker Cable Behind Drywall: Guided Techniques for 2.5m Distance Hiding & Removal
Venom007 23074 17
How can I pull speaker cable behind a drywall wall over a 2.5 m distance and later remove it easily?
Use a vacuum cleaner at the lower hole to suck a thin, strong string through the wall, then use that string to pull a stronger cord and finally the speaker cable behind the drywall [#4154480] Put a very light weight on the string end, such as a wine cork, so the vacuum can grab it [#4154480] This method worked even with a non-straight path, and the original poster reported hiding four cables in about 30 minutes [#4154480][#4154613] If the distance is too hard to aim, drilling an extra hole between the two points can make it easier to guide the wire [#4154400]
  • #1 4154256
    Venom007
    Help: 23
    Rate: 37
    Hello, I recently finished the renovation of my room and now I have a wall of drywall and I would like to pull the cable from the speakers behind this wall because it looks hideous such a hanging cable.
    I have a question for you - do you have any way to put the cable at the top into the hole and somehow easy to remove the cable at the bottom? :| I was tired all day and nothing came of it, some strings with a screw and a magnet from the hard drive, some hard cable and trying to push the cable through, nothing came out of me.
    So if someone has any good way to thread this cable, please share this information.
    The distance between the holes is 2.5m
    Regards
  • #2 4154330
    waldekg
    Help: 69
    Rate: 169
    Hello. If there is free space between the holes, then there is something to be done. I think you will need an additional hole and a piece of fairly stiff wire and a lot of patience.
  • #3 4154369
    Venom007
    Help: 23
    Rate: 37
    Yes of course there is a gap between the record and the wall, there is a lot of free space for the record.
    With this hard wire, I tried to make an "L" and tried to hit the target hole with this "arm" but nothing came of it :|
    Extra hole? what for?
    Regards.
  • #4 4154400
    waldekg
    Help: 69
    Rate: 169
    Hello. An additional hole between these holes will reduce the distance and make it easier to aim with the wire.
  • #5 4154422
    zas
    Help: 9
    I propose not to push the cable at once, but first pull some string, you can hang a small weight and release it at the top and try to pull it out at the bottom. Once the string is pulled, tie the cord to it and pull it back.
    Regards
  • #6 4154443
    Venom007
    Help: 23
    Rate: 37
    ZAS I tried :| as a thinner, I used bolts with nuts, but I have no way of directing this weight to the hole and there is no way to remove it because the holes are not in a straight line :|
  • #7 4154457
    Tommy82
    Help: 455
    Rate: 1073
    I propose such a patent to put a string with a weight on the top, swing it and try to catch a swinging weight, and exactly the string with a hook or a wire with a hook, it is probably called a crochet hook
    even for sure
  • #8 4154480
    ivorpl
    Help: 32
    Rate: 44
    and you tried like this ... it will work out if the horizontal distance of hole 2 is not too large from the distance on the floor to the projection of hole 1 ... namely in hole number two we put a vacuum cleaner pipe and max suction ... we push into hole 1 a string - thin and quite strong, at the end of which we put a light load, e.g. a wine cork so that the vacuum cleaner can suck in ... maybe it will be as possible, at least approximately from hole 1 to hole 2 ...
  • #9 4154613
    Venom007
    Help: 23
    Rate: 37
    ivorpl Thanks!! The job is done :D 30 minutes and 4 cables hidden :)
    Unfortunately, I drilled one more hole, but somehow the old ones will stick :) the vacuum cleaner pulled out a string and the cables were stretched.
    Now you can see the effect of a mini renovation :)
    I regret that I did not write this topic earlier :)
    In this department it did not help, therefore 5 points for colleagues and 10 for ivorpl so symbolically :)
    Regards
  • #10 4154631
    ivorpl
    Help: 32
    Rate: 44
    thanks venom ... I recommend myself for the future hehe :D
    ps. what else can household appliances be useful for? :D :D :D
  • #11 4155171
    Tommy82
    Help: 455
    Rate: 1073
    Also thank you
    and I admit that the idea of a vacuum cleaner is simply brilliant
  • #12 15501971
    tomeeh
    Help: 46
    Rate: 92
    sorry for reheating the old chop, but I think there is no point in duplicating the topic.
    Well, I have the same problem as my colleague described here, except that I also have wool behind plasterboard (Fermacell). I guess the idea with a vacuum cleaner will not work for me. Does anyone have any other proven "patent"? Maybe some facilitation in my situation is that both holes - the top and bottom - will lie vertically.
  • #13 15502336
    Zdzicho
    Help: 77
    Rate: 71
    A useful tool for feeding the pilot is an ordinary tape measure. Of course, its beginning should be properly prepared so that it does not get in the way, it is properly stiff and also flexible as needed.
  • #14 15502481
    tomeeh
    Help: 46
    Rate: 92
    Yes, that's also a good idea, also because the tape is metal. So after inserting it with the top, I could first use a metal / wire / high frequency field detector (I don't know what it's called exactly, but my buddy has it) to check if I am hitting the hole at the bottom. As I wrote, I have insulating wool inside, so the weight is definitely not enough for me to hit the bottom hole.
  • #15 15502590
  • #16 15505179
    tomeeh
    Help: 46
    Rate: 92
    OKAY,
    then I will look for a large magnet. For me, the thickness is 2x12.5mm or 25mm. Hope the magnet won't let me down.
    For safety reasons, it would be appropriate to insert a protective tube?
  • #17 15505213
  • #18 15505243
    tomeeh
    Help: 46
    Rate: 92
    It does not have double insulation, but it is a speaker cable for the cinema. The current / short circuit protection is therefore already rather in the amplifier.
✨ The discussion revolves around techniques for pulling speaker cables behind drywall over a distance of 2.5 meters. Users share various methods to facilitate this process, including creating an additional hole to reduce distance, using a string with a weight to guide the cable, and employing a vacuum cleaner to pull a string through the wall. One effective method involves attaching a steel nut or neodymium magnet to a thin string, allowing it to be guided through the wall using magnetic attraction. Concerns about insulation and safety are also addressed, particularly regarding the use of protective tubing for speaker cables. The conversation highlights the importance of patience and creativity in solving the cable routing challenge.
