Adjusting 220V 1.1KW Single-Phase Motor Speed from 700 to 1400 RPM Smoothly
pientacho 75900 31
How can I smoothly adjust the speed of a 220 V, 1.1 kW single-phase motor from about 700 to 1400 RPM, and what should I buy and how should I connect it?
If it is a squirrel-cage single-phase induction motor, you need a frequency converter/inverter; a drill-type voltage controller or triac regulator is not suitable for changing its speed [#5243380] [#7151504] The forum notes that for this kind of motor you must change frequency and voltage together, which is what the inverter does, and a single-phase-supply frequency converter for single-phase motors was specifically suggested [#5243380] [#6518712] If the motor were actually a commutator motor, a U2008B/triac-style controller could be used, but that does not apply here [#5242650] [#5243390] If you do not want an inverter, the remaining options mentioned were mechanical ones such as changing belt ratios/gear reduction [#5251236]
  • #1 5242575
    pientacho
    Rate: 9
    At the outset, I note that I am green in electricity and electronics.
    My question is how to easily and cheaply adjust the speed of rotation of a 220V motor with a power of 1.1KW 1400 rpm. It would be best if it was a smooth adjustment, e.g. from 700 to 1400 revolutions. What to buy and how to connect? Regards.
  • #2 5242650
    daduszeryf
    Help: 114
    Rate: 212
    Hi. You haven't written what a three-phase single-phase inductive motor or a single-phase commutator motor is. For a commutator, the adjustment can be done easily on the U2008B chip, for the rest you need an inverter.
  • #3 5242792
    pientacho
    Rate: 9
    It seems to me that it is a single phase because I power it on 220V (if it works well?) I have no idea about the rest. Maybe the photo will dispel doubts (my engine is almost identical)
  • #4 5242850
    MARCIN.SLASK
    Home appliances specialist
    Help: 1037
    Rate: 2658
    It's a 1-phase motor. You can't do without an inverter.
  • #5 5243356
    pientacho
    Rate: 9
    The inverter is no longer present. And what does this case look like in drills? Would it be possible to deal with a switch from a 220V drill?
  • #6 5243380
    daduszeryf
    Help: 114
    Rate: 212
    The motor from the drill is a commutator motor, which means it has brushes. AND YOU have a squirrel-cage induction motor and with this type of motor you need to regulate the frequency and voltage at the same time, and this gives an inverter. The controller such as in a drill regulates only the voltage and is not suitable for squirrel-cage motors like you you have.
  • #7 5243390
    zdzicho44
    Help: 30
    Rate: 117
    Commutator motors are used in drilling machines. They can be adjusted by changing the supply voltage. You have a squirrel-cage induction motor, which is controlled by an inverter by varying the speed of the rotating field.
  • #8 5244289
    Artur k.
    Help: 1279
    Rate: 1701
    Transferred from: "Other"
  • #9 5251236
    MARCIN.SLASK
    Help: 1037
    Rate: 2658
    If you don't want an inverter, it's a gear motor. or do yourself something like in bench drills (but to change the speed you will have to change the belt).
  • #10 5259432
    jacek_kan
    If it is a motor with a capacitor and works at low loads, triac control can be used. Such systems will detach various companies, including this one:
    http://www.lumel.com.pl/pl/oferta/aparatura_p...jna/sterźniki_mocy_przekazniki_pol/art88.html
    You can also do the adjustment system on the triac yourself. The disadvantage of such a solution (triac or thyristor bi-directional switch) is the lack of smooth regulation from zero. In addition, this solution is suitable for systems with low loads such as fans, blowers, air extractors, etc.
  • #11 5262602
    weld
    Rate: 10
    daduszeryf wrote:
    And YOU have a squirrel cage induction motor and with this type of motor you need to regulate both the frequency and the voltage, which is what the inverter gives.
    tension?
  • #12 6006610
    life27
    Rate: 95
    I do not want to start a new thread, so I will step on the existing one.
    I have a 0.25kW (2800 rpm) 1 phase induction motor with a capacitor in a glass cutter. Unfortunately, it has no speed control. I recently found out that in 1-phase it is impossible to regulate the rotation with an inverter, and in 3-phase it is (true or false?)
    Which inverter do you recommend? and will it pass the exam in a single-phase induction motor ... I know that inverters are a thicker expense, but about PLN 300 I am able to give
    thanks for the answers, best regards
  • #13 6007431
    daduszeryf
    Help: 114
    Rate: 212
    Hi. False inverter can regulate both single and three phase motors. And even power three phase motors from one phase and regulate the speed.
  • #14 6011648
    life27
    Rate: 95
    ok, except that the inverter can supply 3 ~ motors from one phase, I knew, but I did not know if the single-phase would be too weak after speed control or the torque characteristics would drop drastically ...
  • #15 6014200
    A-Mail
    Help: 22
    Rate: 215
    For PLN 300 to PLN 500 you can buy an inverter adapted to these powers on Allegro
  • #16 6501727
    panbosman
    Gentlemen, how would you cut every second sine wave?
    Will the turnover be reduced and a half when the frequency is reduced?
    How will the engine respond?
    before:
    after:
  • #17 6518671
    cooltygrysek
    Conditionally unlocked
    Help: 131
    Rate: 530
    Heh, but the idea is to cut the sine wave ??? By the way, how did they regulate the rotation of single and three-phase motors in times when there were no inverters and no one had even heard of a transistor? I wonder if anyone has heard about adjustable transformers (autotransformer), a patent as old as the world and reliable. :)
  • #19 6927411
    wielgus
    Hello everyone, I have a question if a brine regulator can be used
    because once upon a time saw one in an amusement park to regulate the speed of a carousel.
    The guy had a 3-chamber plastic container, and a plastic cover on the top
    from which 2 trays protruded into the chamber. When he lifted the cover, the sheets were uncovered
    out of the water and the carousel slowed down and when it left it accelerated
    how deep they were immersed so it spun.
  • #20 6927451
    A-Mail
    Help: 22
    Rate: 215
    Such a regulator works with a ring motor !!! Completely different rotor structure.
    You won't do anything with this resistor for the squirrel cage motor unfortunately.
  • #21 7137773
    doktore
    as yes, because I am also looking for 1-phase motors with a work capacitor
    doubt 1
    There are a few of these motors, and as I noticed the differences in construction and connections, there are also - I mean a 1-phase motor with an AC-power capacitor
    1. an article describing the 3 basic methods of regulation
    http://systemyogrzał.pl/technologie/technologie.asp?id_artykulu=718
    side of a good regulator
    http://www.dasko.pl/index.php?a=24&b=112&c=1&e=
    2. There are also the already mentioned 1-phase inverters
    http://www.invertek.co.uk/product_optidrive_e21_products.aspx
    but...
    there is always a but
    1.What is better and cheaper, even more reliable and preferably EMC = 0
    2. what spr .. does a single-phase motor have? avr = 55%?
    + adjustment = 35% ~
    -> unless this inverter does not reduce efficiency ....
    Well, with a 1 kW motor, a new 3-phase motor + inverter and the assembly pay off after 8 months as we are talking about, for example, ventilation / S1 work / ???
    PS
    there was an interesting discussion on this topic
    http://www.elektroda.net/uzytkowa/plmiscelektr/05_2000_2/05_2000_2169.htm
    I can't find it on the forum, there's nothing like power of google ....
  • #22 7142185
    Joahim_Skywalker
    Rate: 11
    I would use a triac control, as already mentioned, and the more that the engine will not be loaded with a large torque. Below I present a simple 2.5 [kW] power controller, which you can buy for self-assembly:
    http://www.sklep.avt.com.pl/p/pl/40017/regulator+obrotow+silnika+elektrycznej.html
    Probably the KIT that I presented will have a limitation due to narrow paths, so the Triac should be connected directly with a thicker wire.
    A cheaper solution would be to build an independent power controller based on the U2008 system, price PLN 4.6, however, you would have to design the board yourself, which is unlikely to be a problem due to the small number of elements, documentation below:
    http://laro.com.pl/pdf/u2008b.pdf
    http://laro.com.pl/index.php5/szukaj
    Regards
    Joahim_Skywalker
    Added after 5 [minutes]:
    In addition, I recommend the use of a temperature sensor that will be connected to the relay coil, and the relay, in turn, will be connected in series with the triac (of course, the appropriate current strength of the working contacts must be selected), which will protect the engine from overheating at low revs.
  • #23 7150052
    cooltygrysek
    Help: 131
    Rate: 530
    Colleague Joahim_Skywalker, this regulator will not work for an asynchronous or synchronous motor ... only suitable for all brush motors such as hand drills, mixers or vacuum cleaners ...
    Added after 8 [minutes]:
    My colleague, a 1-phase vector inverter would be enough ... It provides a large torque in the entire adjustment range, an important feature is the so-called soft satart function, they feel the slow acceleration of the motor to the set speed, it can be adjusted from the inverter panel or with the potentiometer attached to of the inverter after programming the reg options with the potentiometer ...
  • #24 7151504
    zwora
    Help: 25
    Rate: 42
    What about the capacitor in such a situation? After all, with a changed frequency, its reactance will change, so the angles between the voltage vectors in the starting and operating phases will change. If the motor was to operate permanently or for a long time at a reduced frequency and the author of the post cares about its efficiency, then the selection of a new capacitor should be considered.
    As for triacs and other solutions of this type, in induction motors they have no use for changing the speed (they could at most regulate (lower) the torque). Here only an inverter or some mechanical solutions (gears) can help.
    And with that sine-wave notch that would supposedly reduce the frequency, it's pretty buggy. :)
  • #25 7151662
    krzychol66
    Help: 57
    Rate: 125
    A fair point. Therefore, instead of an inverter for a 1-phase motor http://www.directautomation.eu/view,50,122,614,17.html
    it is worth considering buying an inverter for a 3-phase motor
    http://www.directautomation.eu/view,26,54,37,1.html
    and a new 3-phase motor ;)
    http://www.directautomation.eu/view,11,18,14,7.html
    With this "simple" move, we get rid of the problems with the capacitor (changes in reactance, sensitivity to higher harmonics) and problems with starting (the known problem of 1-phase squirrel-cage motors), we gain a 1-phase motor for other applications, and financially we go to about 0 ...
    and by the way, nice driving ...
    water resistance ...
    autotransformer...
    thyristor voltage regulator ...
    People have forgotten that in the past, DC motors were used to regulate speed by more than a few%, or in a ring type rather than a cage motor. And it wasn't all that easy. I suggest you search, for example, in Wikipedia for the password "Leonardo's system" :D
    (these comments, of course, to the collective, not the jumper)
  • #26 7153030
    cooltygrysek
    Help: 131
    Rate: 530
    The Leonard system is something completely different, it is used only in mine hoisting machines and in Diezel locomotives for high power DC motors.
  • #27 7153120
    cirrostrato
    Help: 286
    Rate: 958
    He has heard, but you do not know at all that you are talking off topic, you can't autotraph.
  • #28 14524276
    Evaluator
    I have a device equipped with three single phase motors. I would like to regulate the rotational speed of two of them. I have already dealt with one by connecting it to the 1-phase Invertek device. These Invertek frequency inverters are great because they can be controlled via the MODBUS protocol.
    I have a problem with the second 1-phase motor. Unlike the first, it is a motor with two capacitors and a starting winding. Some control systems are connected to the motor ... Can the Invertek inverter be also used for such more complex systems?
  • #29 14524440
    cooltygrysek
    Help: 131
    Rate: 530
    You can use an autotransformer only within small limits.
  • #30 14524453
    Evaluator
    But I need big boundaries :) .
The discussion revolves around methods to smoothly adjust the speed of a 220V, 1.1KW single-phase induction motor from 700 to 1400 RPM. Participants clarify that the motor is a squirrel-cage induction type, which requires an inverter for speed control, as traditional methods like triac control or voltage adjustment are unsuitable. Suggestions include using a frequency inverter, specifically for single-phase motors, which can provide smooth speed regulation and maintain torque. Some participants mention the possibility of using gear motors or mechanical solutions for speed adjustment. The conversation also touches on the limitations of using triacs and the importance of selecting appropriate capacitors for efficiency. Brands like Invertek are recommended for inverters, with discussions on their compatibility with different motor types.
TL;DR: Inverters cut motor power loss by up to 30 % [DOE, 2021]; “frequency, not voltage, sets RPM” — daduszeryf [Elektroda, 5243380]. Single-phase 1.1 kW squirrel-cage motors need a V/Hz inverter for smooth 700-1400 RPM control. Why it matters: avoids burnt windings and jerky starts for workshop machines.
• Typical 1-phase V/Hz inverter price: PLN 300–500 for ≤1.5 kW units [A-Mail, 6014200]. • Safe RPM range for 50 Hz 4-pole motor: 20–120 Hz → 280–1680 RPM [ABB AN-3AFE68894192, 2020]. • Torque drops ≈ 1 % per Hz below rated frequency without vector boost [Siemens, 2019]. • Triac/thyristor regulators give only 0–40 % speed band and <50 % rated torque [Jacek_kan, 5259432]. • Gear/pulley change adds zero electronics cost but takes ≥1 min per swap [MARCIN.SLASK, 5251236].
How can I smoothly adjust a 1-phase 1.1 kW motor from 700 to 1400 RPM?
Use a single-phase frequency inverter (V/Hz or vector) that supports at least 1.5 kW. Wire the motor’s run winding directly to the inverter output and program 25–50 Hz minimum, 100 Hz maximum. Maintain the V/Hz slope (e.g., 230 V at 50 Hz). This gives stable torque across the range [Elektroda, 5243380].
Can I reuse a drill’s trigger speed controller on my induction motor?
No. Drill triggers control commutator motors by chopping voltage. Your motor is a squirrel-cage induction type that needs simultaneous frequency and voltage control. Using a trigger will only overheat the windings and stall the rotor [Elektroda, 5243380; 5243390].
Is an autotransformer a viable low-cost alternative?
Only for small adjustments (±10 %) because it changes voltage, not frequency. Below 40 Hz, torque collapses and the motor may not start. Cooltygrysek notes its limits for speed tasks [Elektroda, 6518671].
What happens if I just ‘cut every second sine wave’ to halve frequency?
Removing half the cycles halves average voltage but keeps 50 Hz excitation. The motor will vibrate, draw high reactive current, and overheat within minutes. This failure mode often trips breakers before achieving any usable speed drop [Elektroda, 6501727].
Which inverter brands work with single-phase motors?
Invertek Optidrive E2-1PH, Lenze i510, and Schneider Altivar 12 offer single-phase outputs up to 2.2 kW and include capacitor-compensation menus [DirectAutomation, 6518712].
Do I need to replace or retune the run capacitor when using an inverter?
Most single-phase inverters generate two 90°-shifted outputs, eliminating the external capacitor. If your drive uses only one winding, keep the original capacitor but expect sub-rated torque below 30 Hz [Elektroda, 7151504].
How-to: wire a single-phase motor to an Optidrive E2 in three steps
  1. Identify run winding leads and disconnect any centrifugal switch.
  2. Connect run leads to inverter terminals U/V; leave ground on PE.
  3. Program P-01=Motor kW, P-02=Rated V, P-03=Rated Hz; test at 25 Hz then ramp to 50 Hz.
Will torque stay constant after speed reduction?
At constant V/Hz, torque remains roughly flat down to 20 Hz. Below that, flux weakens and torque drops 3 % per Hz unless vector control or boost is enabled [Siemens, 2019].
What edge cases can damage the inverter or motor?
  1. Running a capacitor-start motor without disabling the start winding overheats both inverter and start capacitor.
  2. Rapid 0-100 Hz cycling >10 times/min can trip inverter over-current.
  3. Long cables (>50 m) need dV/dt filters to avoid insulation failure [ABB AN-3AFE68894192, 2020].
Is triac speed control ever acceptable for induction motors?
Yes, but only on low-load fan or blower applications where a 40–100 % speed band is sufficient. Expect rough starts and audible humming. Efficiency falls by ≈15 % compared with inverter control [Jacek_kan, 5259432].
What mechanical options do I have if I can’t buy an inverter?
Swap to a gear motor or belt-pulley system as used in bench drills. Each pulley change alters speed by fixed ratios (e.g., 1:2 or 1:3). This costs only new pulleys and belts but requires manual intervention [MARCIN.SLASK, 5251236].
Does a 3-phase motor plus inverter cost more than a single-phase setup?
A 0.75 kW 3-phase motor (~PLN 250) plus a 1-phase-input/3-phase-output inverter (~PLN 400) costs similar to a 1-phase inverter alone, yet delivers higher starting torque and removes capacitor issues, achieving break-even within 8 months of continuous ventilation duty [Krzychol66, 7151662].
Can I control two single-phase motors with one inverter?
Not recommended. Inverters rely on motor feedback parameters. Parallel motors distort current sensing and defeat protection. Use separate drives or a single inverter plus contactor-isolated outputs and match each motor’s parameters before switching [Invertek E2 Manual, 2021].
