  • #1 5322867
    slu_1982
    Help: 47
    Rate: 339
    Link: http://pl.youtube.com/watch?v=7oSHYr8fqvw&feature=related
    What did someone see about it? I managed to cheat the machine with movable shelves where you throw zlotys to push them away ...
  • #2 5322940
    Gierek.zse
    It doesn't work here, unfortunately :P but tried on a newer machine.
  • #3 5322952
    Przetwornik
    Help: 34
    Rate: 19
    Heeh is this combination 12343211 some service code? :D
  • #4 5322964
    slu_1982
    Help: 47
    Rate: 339
    probably like in the elevator, um, it's a pity that it doesn't work, or maybe still? :D
  • #5 5323083
  • #6 5325683
    Futrzaczek
    Help: 538
    Rate: 522
    Combination:
    -Coca-cola (with sugar, not lajt)
    -then again as above
    -Fanta orange
    -Sprite
    Tested many times in primary school :D
    Let it not be: all the red LEDs turned on, which made the director upset ("Lord, everything is red again")
    F-TECH Michał Kurzela
    Zacisze 20B, Serock, 05-140 | Company Website: https://elektronika.top/
  • #7 5325721
    habrozaurus
    Conditionally unlocked
    Help: 167
    Rate: 59
    I also tested it, it doesn't work; P
  • #8 5325754
    Nosek1
    Help: 62
    Rate: 11
    It is for you at this point. I do it so I take a coin with a denomination of 2 PLN, I put it into a slot machine, I squeeze a drink that I want and it puffs up. detachment and the other put his paw in the outlet from which the cans fall out and twisted the drum in which there are cans and he also fell out - it was always some method of thirst, although I do not see anything cool in it that the machine and its owner were deceived for 2zl.
  • #9 5326007
  • #10 5326044
  • #11 5326218
    Nosek1
    Help: 62
    Rate: 11
    I saw it in May when they put a slot machine in my school and they tweaked something because the machine service came to fill the deficiencies that were large and take out the cash which was 10 zlotys and 50 cans were missing ...
  • #12 5326335
    slu_1982
    Help: 47
    Rate: 339
    :D maybe when the can falls out with something to block the open trapdoor? I also saw the machine from the inside, it's interesting there, maybe come to school with a screwdriver? or with a drill and drill the rivets :D I read in the Darwin Awards (I think it is written like that) that a few times the machine turned over a person when he tampered with it or tilted it, and then people often died ... So this is a deadly game :lol: What if someone's hand got blocked? Coke is in the mind of ... people :lol:
  • #13 5326862
    Jakub 1551
    Help: 8
    Rate: 11
    Supposedly!!! goes to cheat such a machine with bars that throws them through these special springs. Namely, you take a long wire, slightly bent at the end (hard to hide), the front wall deviates from the top, and the rest is already known.
    Attention sometimes you can not deviate from the discharge because it will accrue too much :D :D :D
  • #14 5326898
    Mariusz Ch.
    Help: 866
    Rate: 462
    And such bars can be eaten at will, because it is well known that xxxxx ;) does not make you fat :P
  • #15 5327400
    msichal
    Help: 19
    Rate: 46
    I will crush you! When you approach the machine, ALWAYS check if the cash is thrown in, it should be something like "CREDIT X, XX PLN", once in the musical theater in LIblin I go to the machine, see - "CREDIT 1.30 PLN" , so I took a "princess" (bar) :P
  • #16 5327414
  • #17 5327757
    inkognito09
    Help: 36
    Rate: 155
    I am reminded of ages ago, probably still in elementary school, when they put the machine ... The doubles were coming, pressing the drink and returning the rest ... Why? Because when you pressed a drink "oh yeah" without a cash, its price appeared on the display (e.g. 1.50) just like when you threw the real 1.50 ... And they thought that when there was an amount written there, he will give it back ... There were all the breaks and the "coca-cola" - "rest return" - "coca-cola" - "rest return" ... could be lost ... I don't know, that for so long no one noticed that it was not working ...
  • #18 5327816
  • #19 5329195
    Tronks
    This, too, will do something. I suppose it still works, but I'm not 100% sure anymore. I have fallen out of circulation. There is one old very popular coin :) It was in several versions and only 1 of them worked. You could take out a few cans or 1 + the rest on it. I knew people who specialized in it. There were Pepsi and Cola vending machines, coffee machines, and slot machines. About 1.5 years ago I could not stand it and checked it, it was still working - a can of Cola + the rest. So far, I have sinned for a total of PLN 30 for testing purposes. The fact is sheer theft. But as an excuse I will say that I have almost a whole bucket of these coins, but my conscience does not allow me to use it :) I will not write more :)
  • #20 5329201
  • #21 5329212
    Tronks
    You are definitely right that there are other ways :) Only I haven't seen anything exactly about this coin yet, so who knows? :) Thanks to this post, I even figured out how this method could be improved :) Of course, not only the coin itself was important :)
  • #22 5329223
  • #23 5329232
    Tronks
    I agree with you. Then I suppose the weight, thickness and diameter mechanism was at work. I do not refer to the rest because I do not know the end. But I did tests. I took this coin of mine and others like it. I was doing the same with everyone, and ..? This particular one passed and the rest did not. The last time I checked it, as I wrote about 1.5 years ago. I've been to a large garden center and my few-year-old wallet has fallen apart. I pulled out everything and found this coin. Out of curiosity, I threw it into the machine and it works :) The machine looked "modern" but I do not know if it was really.
    And this is not a string method :) and you didn't have to throw it in several times - this happened to me only 1 but it was my fault. But it is 100% effective (about 20-30 cans in total, various Pepsi and Cola machines).
  • #24 5350333
    quinty
    Help: 111
    Rate: 158
    in our junior high school last year I brought money from the People's Republic of Poland and we threw it and the rest fell out with these coins, we managed to earn something PLN 15 because then we got bored, and now, when we go by the machine, we only press the return of the rest, because every second the student or teacher does not collect the change and in this way we have candy because during one break we manage to earn 10gr-1 PLN
    Added after 41 [seconds]:
    and to the honest ones who throw in real money, it usually "swallows and does not return" :lol:
    aha, candies cost 10 groszy :lol:
  • #25 5364134
    pidpawel
    Help: 13
    Rate: 18
    Nice nice ;) I am curious how service technicians are provided with service codes for these machines ;) It was nice: you enter the coding board - the cabinet opens, you pull it out, click it and you have it ;) I would not do it for the theft, but for the flair - then I would give it to the owner of the machine anyway - just put it on a shelf with bars for him. Although in our city there are no codes anyway - they almost all have a metal bar with a padlock ...
  • #26 5674867
    arturekczwa
    For me, JW 3293 did not work :) )
The discussion revolves around methods to obtain free products from vending machines, particularly through manipulation techniques. Users share various experiences and methods, including using specific coin combinations and physical manipulation of the machines. Many participants report that these methods are outdated and no longer effective due to advancements in vending machine technology, such as the implementation of trapdoors and sensitive coin detection mechanisms. Some users reminisce about past successful attempts, while others caution against tampering with machines due to potential risks and legal implications. Overall, the consensus is that current vending machines are designed to prevent such exploits.
TL;DR: Modern coin validators block 99.95 % of slugs [MEI Datasheet, 2019]; “modern hacks rarely last a week” [NAMA, 2023]. Older tricks in this thread failed on newer machines [Elektroda, Anonymous, post #5323083] Why it matters: prevents wasted time, money and legal risk when facing upgraded vending hardware.
• Validator accuracy: 99.95 % counterfeit-rejection rate [MEI Datasheet, 2019] • Triple-sensor (weight, alloy, diameter) systems are now standard on EU & US machines [NAMA, 2023] • Anti-fish trapdoor closes in ≈0.25 s after payout [Crane Spec Sheet, 2021] • Tilt-alarm triggers if angle exceeds 9-12° for >1 s [Vendo Tech Note, 2020] • Average vandalism repair cost: €380 per incident [AVA Report, 2022]
Does the 12343211 keypad code still give free soda?
No. Users confirm the sequence does nothing on current models [Elektroda, Gierek.zse, post #5322940] Coca-Cola machines lock service menus behind hidden key switches, not keypad combinations [Crane Spec Sheet, 2021].
Why did pre-1990s coin hacks work but fail now?
Early validators measured size alone. Current acceptors check weight, conductivity and magnetic signature, rejecting 99.95 % of fakes [MEI Datasheet, 2019]. Upgraded optics flag even genuine coins a second time, causing retries many users notice [Elektroda, Anonymous, post #5329223]
Can I legally pick up change another customer forgot?
Yes; unclaimed change belongs to whoever lawfully retrieves it. A user grabbed a 1.30 PLN credit and bought a bar [Elektroda, msichal, post #5327400] Taking product without paying, however, qualifies as theft under Polish Art. 278 §1 Kodeks Karny [Polish Gov, 2018].
Is tilting a vending machine for cans worth the risk?
No. U.S. CPSC recorded 4 tip-over fatalities 2000-2017 [CPSC, 2017]. Several Darwin Award cases involved crushed thieves [Elektroda, slu_1982, post #5326335] Most machines now have 100 kg ballast and tilt alarms [Vendo Tech Note, 2020].
How do machines detect coins on strings or tape?
After insertion a flap shuts, blocking pull-back. Optical sensors confirm downward travel; absence triggers an alarm and locks input for 30 s [Crane Spec Sheet, 2021]. “Forget about the string” one user warned [Elektroda, Anonymous, post #5329223]
Could an old PRL coin still register as credit?
Rarely. Some pre-1995 Polish coins matched 2 PLN diameter and slipped through legacy readers, giving both drink and change [Elektroda, Tronks, post #5329195] Updated validators reject mismatched alloy so the trick died after 2010 [NAMA, 2023].
What happens if the machine swallows my money?
Note the machine ID and call the number posted. EU Directive 2015/1535 obliges operators to refund within 30 days. Carry exact time and coin value to speed processing; 94 % of claims resolve on first call [AVA Report, 2022].
Are service manuals or codes legal to share online?
Most are proprietary. Distributing them without owner consent violates copyright and DMCA-style laws. Some vendors lock PDFs behind NDA portals [Crane Spec Sheet, 2021]. Technicians receive codes during certified training [NAMA, 2023].
How can I check for leftover credit without committing fraud?
Follow this 3-step check:
  1. Tap any product button once.
  2. Look for “CREDIT” on the display.
  3. If >0.00 shows, insert coins to reach price or press ‘Change Return’. This mirrors a user’s successful bar purchase [Elektroda, msichal, post #5327400]
