Candy G04 F 106 Grand Washing Machine - Padlock Flashing, Water Pump and Door Lock Issues
wuwik 8418 8
  • Pump works, but padlock still flashes after start
    #1 16752553
    wuwik
    Rate: 15
    At first, the symptoms were that after finishing washing, she refused to pump water. I unhooked the pump and fired briefly. The water was elegantly pumped out. I took out the programmer which looks fine. I checked the brushes and it was okay too. After folding, no program starts. After pressing the start button, the padlock flashes and that's it. I put a new door lock and nothing helped either.
  • #2 16755871
    domis33
    Help: 13
    Rate: 220
    Buddy, and by any chance the parental lock is not on?
  • #3 16756199
    wuwik
    Rate: 15
    I have read the manual and there is no word about parental controls, and is there a washing machine reset sequence or some self-test?
  • #4 16756514
    zibi1971
    Home appliances specialist
    Help: 262
    Rate: 1120
    View the module.
  • #5 16777811
    wuwik
    Rate: 15
    the module looks alive and well
  • #6 18716111
    Tomasz Filipiak
    I stick to the topic. If the problem was solved, I have the same thing.
  • #8 18716392
    Tomasz Filipiak
    The lock has been checked and replaced with the second one. I connected even without a lock, making a transition. Heater for leakage checked with a meter and it's OK. Heater resistance about 27?. The board looks healthy. A lot of brushes and a tachogenerator is OK. It happens that sometimes it will surprise you especially when you just set it spinning and with longer disconnection from the power supply. The padlock light blinks regularly with no gap.
    After gently blowing air, the hydrostat closes the transition's contacts. Solenoid valves OK. I have not checked the drain pump, but when it clicks, the pump sounds. When it comes to the parental lock, I checked the delay. The program can also be deleted. After setting the new lock, it will pop, block the door, it will make a passage (I checked) and only the light blinks. What else to cling to? Any hints?
  • #9 18730826
    Tomasz Filipiak
    Welcome back. I think I have solved my problem as I only tried spinning and one program but no water connected.
    For me, after selecting the program and, for example, deleting or ending the program, wait until the lock releases the bolt, i.e. reset and give the knob to the off position, wait for the lock to "click". Now use the knob to set the program, press start and the washing machine starts. It is not possible to delete the program, switch the program and start it without switching off and releasing the lock, at least for me.
    Greetings.
The discussion revolves around issues with a Candy G04 F 106 Grand washing machine, specifically related to a flashing padlock indicator, water pump failure, and door lock problems. The user initially reported that the machine would not pump water after completing a wash cycle, despite the pump functioning when tested separately. Subsequent troubleshooting included checking the programmer, door lock, and various components such as the hydrostat and solenoid valves. Suggestions from other users included verifying the door lock and module, as well as performing a reset sequence to clear the lock mechanism. One user shared a potential solution involving waiting for the lock to release before starting a new program. The conversation highlights the complexity of diagnosing electronic appliance issues and the importance of systematic troubleshooting.
