Intermittent Orange Oil Light with Wave on Opel Combo 1.3 CDTI - Causes?
artusek 140374 5
  • #1 5325648
    artusek
    Rate: 85
    Welcome to the car, as in the topic, the orange oil light with a wave underline lights up from time to time.
    What does it mean and how to diagnose the cause and remove it?
    I attach a photo:
    Thank you in advance for your help !
  • #2 5326692
    ptaszek1975
    Level 30  
    Help: 121
    Rate: 444
    My friend, I see it for the first time, but in VW T4, if you have driven more than 15,000 km on oil, a similar oil can will light up, it is a sign that you need to change the oil, the oil is not of this viscosity.
    carrot
    Moderator of Cars
    Help: 1315
    Rate: 3603
    Sump oil level, sensor too low or faulty
  • #4 5334354
    artusek
    Rate: 85
    The car is flooded with fresh oil for about 3,000 km in accordance with the manufacturer's specification ... Is the information about the oil level in the sump certain or is it just a suggestion?
    Thank you !
  • #5 5334416
    kwok
    Level 40  
    Help: 496
    Rate: 1342
    if the sensor has not broken, this is certain information
    you can always check the oil level by pulling out the dipstick
  • #6 5334446
    artusek
    Rate: 85
    Oil level OK
    Added after 3 [hours]:
    The case was finally resolved ... according to the suggestions of Carrot and Kwok, the indicator in accordance with the operating manual, which I found on the Internet, means the oil level is too low (or if the level is ok, the sensor is damaged - as in my case).
    I am enclosing a photo of the instructions - sorry for the low quality.
    I would like to thank the Forum members for their help!
